Need to get rid of the 'h' on the denominator
  • Thread starter Thread starter UrbanXrisis
The discussion revolves around the limit expression lim_{h->0}\frac{ln(2+h)-ln2}{h}, which is related to the concept of derivatives in calculus, specifically the derivative of the natural logarithm function at a point.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the transformation of the limit expression and its connection to the definition of the derivative. Questions arise regarding the interpretation of the derivative and the steps involved in manipulating the limit.
Participants are actively engaging with the concepts of derivatives and logarithmic functions. Some have provided insights into the definition of the derivative, while others are questioning specific steps in the manipulation of the limit expression. There is a mix of understanding and confusion regarding the application of these concepts.
Some participants express uncertainty about their prior knowledge of derivatives and the definitions involved, indicating a potential gap in understanding foundational calculus concepts.
UrbanXrisis
[tex]lim_{h->0}\frac{ln(2+h)-ln2}{h}[/tex]
so I need to get rid of the 'h' on the denominator, but how can I do that?
[tex]\frac{\ln (2+h) - \ln(2)}{h} = \ln \left[\left( 1 + \frac{h}{2}\right)^{\frac{1}{h}}\right][/tex]
Do you see why? :smile:
Now, this may or may not help you, depending on how much you know. If you know
[tex]\lim_{n \rightarrow \infty} \left(1 + \frac{x}{n}\right)^n = e^x,[/tex]
and
[tex]\lim_{x \rightarrow a} \ln f(x) = \ln \left( \lim_{x \rightarrow a} f(x) \right)[/tex]
then this is enough for you to do the question.
I really do not understand..
my book explains it as... [tex]lim_{h->0}\frac{ln(2+h)-ln2}{h}=f'(2)[/tex], where [tex]f(x)=lnx[/tex].
what does that mean?
It means that the book applied the definition of the derivative of a function of one variable (which is [itex]f(x)=\ln x[/itex]) at a point from its domain (which is [itex]x=2[/itex])...
It can't get any more clear/elementary than that.
Daniel.
It means that it is the derivative of the function [itex]\ln{x}[/itex] evaluated at [itex]x=2[/itex]. A derivative can be thought of geometrically as a rate of change of one quantity with respect to another. In this case, it is the rate of change of the function [itex]\ln x[/itex] with respect to [itex]x[/itex], at the point [itex]x=2[/itex].
The derivative of a function [itex]f(x)[/itex] at the point [itex]x[/itex] with respect to [itex]x[/itex] is defined to be
[tex]f^\prime (x) = \lim_{h \rightarrow 0} \frac{f(x+h) - f(x)}{h}[/tex]
if this limit exists.
The numerator of the limitand, [itex]f(x+h)-f(x)[/itex], is the change in [itex]f[/itex] between [itex]x[/itex] and [itex]x+h[/itex]. The denominator is the change in [itex]x[/itex], which is just [itex]h[/itex]. As the change in [itex]x[/itex] approaches zero (ie. when we take the limit), we get the instantaneous rate of change of the function with respect to [itex]x[/itex].
Think of it as your good old rise over run to find the slope of a function. Slope is your rate of change, and Fermat(i think) came up with this neat way of computing the slope for a function that's not a line. You pick the point you want which is x then the difference between the point you want and any other point is h, so the denominator on the bottom is your run or difference in x, hence h on the bottom. Then you draw a secant line that crosses that function at the point x and another arbitrary point. The slope would then be (y-y1)/h, y1 is also f(x) in other notation and y is the function evaluated at your point x + your run h, or ((x+h),y), and in other notation f(x+h). Put it all together and you get your function, take the limit of that function as the run aproachers 0 and you get the derivative or slope at that point.
Folklore says that Leibniz discovered diff.calculus while playing with tangents to curves...
Daniel.
okay,I understand all that you have said. f(x) is ln(x).
how do I actually solve the problem?
Daniel.
just to play devils advocate :devil: ...
Sure, after he stole the idea from Newton! :-p
He didn't steal anything.Not even phylosophy and physics...He was a really brilliant man.In the same league with Newton,Euler & Gauss.
Daniel.
See how Data rearranged the limit to a different form in his first response? First, verify that you understand how he got it to that form. Then, see if you can use his second and third formulae to get a result.
What do you mean...?It's already solved with the derivative's definition.
Daniel.
I'm purely joking, as far as I know, Leibniz and Newton discovered the idea independently of each other :smile: .
Not to mention in different context.Was was interested in maths,the other in physics...
Daniel.
If this is like the structure of my old calc class, he may not have covered derivatives yet.
I don't see have Data's second and third equation fit into all of this
I've learned derivatives, I think I just forget the definition of a derivative and how to solve the definition, it was a while back and my class is doing some basic review
If u did,then u'd understand that
[tex]\lim_{h\rightarrow 0} \frac{\ln(2+h)-\ln 2}{h}=:\left \left(\frac{d}{dx}\ln x\right) \right|_{x=2} =\left\frac{1}{x}\right|_{x=2}=\frac{1}{2}[/tex]
Daniel.
Well, if you're allowed to solve this problem by invoking the derivative of a logarithm, just do that. Otherwise:
[tex]\frac{\ln (2+h) - \ln(2)}{h} = \ln \left[\left( 1 +\frac{h}{2}\right)^{\frac{1}{h}}\right][/tex]
Explain to me how this is true so that I can be sure that you're following.
oh my, okay, thanks, I get it
[tex]\frac{\ln (2+h) - \ln(2)}{h} = \frac{ln(\frac{2+h}{h})}{h}= \ln \left[\left( 1 +\frac{h}{2}\right)^{\frac{1}{h}}\right][/tex]
thanks but I understood what dextercioby did :)
[tex]\frac{\ln (2+h) - \ln(2)}{h} = \frac{\ln(\frac{2+h}{h})}{h}= \ln \left[\left( 1 +\frac{h}{2}\right)^{\frac{1}{h}}\right][/tex]
there's a problem in your middle step (and thus the result does not follow from your middle step). Do you see where?~
[tex]\frac{\ln (2+h) - \ln(2)}{h} = \frac{ln(\frac{2+h}{2})}{h}= \ln \left[\left( 1 +\frac{h}{2}\right)^{\frac{1}{h}}\right][/tex]
foolish mistake
however, I did not know that [tex]\frac{ln(x)}{z}=ln(x)^{\frac{1}{z}}[/tex]
indeed, since
[tex]x = \ln e^x[/tex]
and thus for
[tex]e^{\alpha \ln \gamma} = \gamma^\alpha[/tex]
we get
[tex]\ln \gamma^\alpha = \ln e^{\alpha \ln \gamma} = \alpha \ln \gamma.[/tex]
or
[tex]\ln \gamma^\alpha = \alpha \ln \gamma[/tex]
:smile:
Note that you should be a little careful: what you put in your last post is not quite right. It is not
[tex]\frac{\ln x}{z} = \ln (x)^{\frac{1}{z}}[/tex]
but instead
[tex]\frac{\ln x}{z} = \ln \left(x^{\frac{1}{z}}\right).[/tex]
Daniel.
Quite right but i was referring to the method that is used, it was first proposed before calculus by Fermat to find the slope of the line tangent to a point, although it's not the same notation as in calculus here's http://math.kennesaw.edu/~jdoto/13.pdf (goto Fermat's method) .
  • · Replies 36 ·
  • · Replies 28 ·
  • · Replies 58 ·
