Inelastic collision of equal masses and velocities
The discussion revolves around an inelastic collision involving two objects of equal mass, each initially moving with speed v. After the collision, they move together with a speed of v/5.5, and the problem seeks to determine the angle between their initial directions.
  • Participants discuss the application of momentum conservation principles and explore the geometric representation of the collision, including the suggestion of using a diagram to visualize the problem.
There is an ongoing exploration of the correct interpretation of momentum conservation in the context of the collision. Some participants have offered guidance on visualizing the problem through diagrams, while others are questioning the assumptions made in the calculations.
Participants are grappling with the implications of the inelastic collision and how to accurately represent the motion of the objects before and after the collision, particularly in relation to the angle between their initial velocities.
Fanman22
After a completely inelastic collision between two objects of equal mass, each having initial speed, v, the two move off with speed v/5.5. What was the angle between their initial directions?
Well, inelastic collision so it looks like I'll be using the momentum equation in here. My professor loves these "ratio-type" problems and I believe that I'll have to use something of the sort on this.
Momentum in = Momentum out
mv + mv = m(v/5.5) + m(v/5.5)
Not sure where to go from there, and I don't see how I will find an angle out of all of this. Anyone have any sugestions as to where I should start?
No,no,conservation of momentum is a typical example of vector relation/equation...
Sides,in the final state,there's only one particle...:wink:
Daniel.
Fanman22,
Have you tried drawing a picture showing the particles and their directions of travel before and after the collision? If not, it might help.
Yeah,you'd see an isosceles triangle there.It would help you with the projection of the vector equation on some nicely chosen axis of coordinates.
Daniel.
*****http://img.photobucket.com/albums/v225/Fanman22/c7f601bb.jpg *****
Is that even remotely correct? I'm not sure the isosceles triangle idea makes sense to me. I don't understand how it represents the motion of the 2 particles before the collision and how it represents the velocity of the total mass afterwards.
Nope.It should have been more like an Y.Actually exactly like an Y...
Daniel.
I can see the "Y-shape" now...What I did was take the components (in the direction of the final velocity) of each V. So...
Vsin(theta) + Vsin(theta) = (v/5.5) = 2Vsin(theta)
Theta = 5.216
To find the angle between the particles...
180 - 5.216 - 5.216 = the middle angle = 169.6
But of course, I got it wrong again
Where did I go wrong?
Fanman,
You almost have it. But what does your equation:
say is conserved? What's really conserved?
yes what jdavel said
Edit* didn't look too closely myself
  • · Replies 47 ·
  • · Replies 22 ·
