Simple harmonic motion glider problem
The discussion revolves around a simple harmonic motion problem involving an air-track glider attached to a spring. The glider is released from rest and oscillates with a specified period and maximum speed, prompting participants to determine the amplitude of the oscillation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between the maximum speed, period, and amplitude using equations of motion. There are attempts to derive the amplitude from the given conditions, and questions arise regarding the correct application of the equations at specific times during the oscillation.
The discussion has progressed with various hints and insights shared among participants. Some have identified key points about the timing of maximum speed and the relationship between amplitude and period, while others have provided alternative methods for approaching the problem. There is recognition of different perspectives on solving the problem, but no explicit consensus has been reached.
Participants note the importance of the period of oscillation and the conditions of the glider's motion, including its release from rest and its behavior at the equilibrium point. There is an acknowledgment of the complexity involved in solving the equations without clear definitions of time for specific instances.
adrian783
An air-track glider is attached to a spring. The glider is pulled to the right and released from rest at t = 0 s . It then oscillates with a period of 2.40 s and a maximum speed of 46.0 cm/s.
What is the amplitude of the oscillation?
i tryed solving for t by using the equation x(t) = A cos (wt + q) with w = angular frequency and q = phase constant A = amplitude, i tried to solve for the 3 variables by using the equatoin, the derivative of the equation, and the 2nd derivative of the equation ... unsuccesful.
is there an equation other than that one that allows me to calculate the simple harmonic motion? please tell me how to do this problem...
You know some initial conditions. If it is released from rest, then x'(0) = 0
You also know that it is released from rest after being stretched to its maximum displacement: so x(0) = A.
plugging in t = 0
Acos(w(0) + q) = Acos(q) = A
cos(q) = 1
q = 0
You have yet another bit of info: what does the maximum speed tell you (at what point in SHM is the oscillator moving fastest?)
i see what you're saying
the maximum speed occurs when it is at its equlibrium point, x = 0 right?
using the first derivative i get velocity equation, which is:
v(t) = - A w sin (wt) w = 2.61
-46 = - A*2.61 sin(2.61*t) <---this is at the eqi. point, going to the left
but i still have 2 variables in this equation, and i can't seem to solve it with
x(t) = A cos (wt)
0 = A cos (2.61 t) <---this is at the eqi. point, going to the left
how do i solve this set of equations:
0 = A*cos (2.61*t)
Your equations are not quite right, because you haven't figured out at what time they are true. You are still using the variable t. Why? The equations are not true for all time. They are only true at a specific instant (when the object is in the middle). At what time is that? How would you figure it out?
Hint1: you haven't made use of the information given about the period of the motion yet (and by that I mean, you haven't made use of it directly).
Hint2: The bottom equation, even when corrected, will not be required, for it will essentially contain the information: 0=0, at the right time (when the object is at the equilibrium position).
Look carefully at the equation for v. When is v maximized?
Nah! For what purpose? You should already know when v is at its maximum in SHM. That's what my hint1 was alluding to. Don't mess him up! Just follow my hints, adrian.
cepheid said:
Nah! For what purpose? Next time read the thread. Don't mess him up! Just follow my hints, adrian.
Can you explain what you mean by that? :( Isn't it the amplitude that he is looking for, given the period of oscillation?
waiiiit a second..period 2.4 s that's going forward and back...
cut that by half, that's going one way trip
cut that by half again...would it be..could it be..AT THE EQILIBRIUM POINT!?
2.4/4 = 0.6
so the time to arrive at the equilibrium point is...0.6!
now i see, the bottom equation does reduce to 0 = 0 when i plug in the t in
-46 = - A*2.61 sin(2.61*t) t = 0.6
-46 = - A*2.61 sin(2.61*0.6)
A = 17.57!
SWEETTT thanks for all your help!
Ramollari: I edited it for clarity, to explain what I meant. Didn't mean to be rude. And adrian figured it out too, illustrating the point perfectly.
I know you were saying it was at a maximum when sinwT = 1,
wT = pi/2
solve for T and you get the same answer, and equally valid and more mathematical way of looking at it, so sorry I jumped on you.
This is how I'd go to solve it:
[tex]|v_{max}| = \omega A = \frac{2 \pi}{T}A[/tex]
I would just solve for A
[tex]A = \frac{v_{max}T}{2\pi} = 17.57cm/s[/tex].
I think this is more elegant, though the way you solved it is also good.
lol yes, I keep editing my posts on you, which is bad. Yes, as I stated above, I agree it is more elegant.
