Combination of Linear and Angular momentum
The discussion centers on calculating the angular velocity of a solid cylinder after a particle collides with it and sticks. The cylinder has a mass of 42 kg and a radius of 0.14 m, while the particle has a mass of 4.2 kg and an initial velocity of 17 m/s. The correct approach involves using the conservation of angular momentum, where the initial angular momentum (Li = mvR) equals the final angular momentum (Lf = Iω). The moment of inertia (I) for the cylinder is (1/2)mR², leading to the equation ω = Li/Lf for determining the angular velocity post-collision.
  • Understanding of angular momentum conservation principles
  • Familiarity with moment of inertia calculations
  • Knowledge of linear momentum concepts
  • Basic physics of collisions and rotational dynamics
  • Study the derivation of moment of inertia for various shapes, including cylinders
  • Learn about the conservation of angular momentum in inelastic collisions
  • Explore the relationship between linear and angular velocity
  • Practice problems involving angular momentum and rotational dynamics
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of angular momentum and its applications in collision problems.
ness9660
A solid cylinder of mass M = 42 kg, radius R = 0.14 m and uniform density is pivoted on a frictional axle coaxial with its symmetry axis. A particle of mass m = 4.2 kg and initial velocity v0 = 17 m/s (perpendicular to the cylinder's axis) flies too close to the cylinder's edge, collides with the cylinder and sticks to it. Before the collision, the cylinder was not rotating. What is its angular velocity after the collision? Answer in units of rad/s.
Im lost on forming the equation for this problem. Combination of angular momentum problems have been fairly easy using Li/Lf, I thought I would try something similar like this:
Li=m*v for the momentum of the object, and nothing for the cylinder since it is at rest
Lf= (1/2)m1*R^2 + m2R^2
Where m1 is the mass of the cylinder and m2 that of the object.
Then as usual doing w=Li/Lf, however this produces a wrong answer. I think I am missing a key concept here in translating linear momentum to angular momentum because what I am doing is turning out very wrong.
Thanks
The initial angular momentum is [tex]mvR[/tex] assuming the the particle hits right at the top edge of the cylinder.
[tex]L = I\omega = mvR[/tex]
Ah, thank you very much for the help.
18K
  • · Replies 17 ·
  • · Replies 55 ·
