Photocells: Understanding the Basics
  • Context: High School
  • Thread starter Thread starter Kahsi
    Work
The discussion revolves around the functioning of photocells, specifically focusing on the photoelectric effect, the implications of electron loss, and the operational limits of photocells in various applications. Participants explore theoretical aspects, practical concerns, and specific experiences related to photocell performance.
  • Experimental/applied
  • One participant explains that photocells operate based on the photoelectric effect, where light converts into electric current by knocking electrons loose from an electrode.
  • Another participant questions whether photocells degrade over time due to electron loss, suggesting they may become positively charged and inquiring about their longevity.
  • A participant acknowledges the need for a battery to refresh the photocell, indicating uncertainty about the exact mechanisms involved.
  • A later reply discusses the grounding of the semiconductor in photocells, suggesting that without proper grounding, charge depletion could lead to malfunction.
  • Concerns are raised about photocell saturation, where increased light intensity does not result in a proportional increase in current, with various factors influencing this phenomenon.
  • Participants note that the operational limits of photocells depend on their specifications, including power range and frequency response.
Participants express uncertainty regarding the longevity and degradation of photocells, with no consensus on the exact mechanisms or effects of electron loss. Multiple views on the operational limits and grounding issues remain present.
Participants mention various factors that could affect photocell performance, such as charge carrier density, bias voltage, and manufacturer specifications, but do not resolve these complexities.
This discussion may be of interest to those studying or working with photocells, including students, engineers, and researchers in fields related to electronics and photonics.
Kahsi
Hi!
I just have one question, How does a photocell work?
Kahsi said:
Hi!
Well, it works due to the photo-electric effect : the conversion of an EM-wave (light) into an electric current. It is this phenomenon that Einstein explained in terms of quantized energy (of the target atoms of the electrode, NOT the EM-wave) and earned him his Nobel Prize. It also suggested for the first time that EM-waves could be seen as a stream of particles called photons. Einstein did not invent the name photons and i must say that this effect did NOT prove the particle-behaviour of waves, it just suggests it. This is a common misconception.
The incident light knocks lose conduction electrons from the target electrode. This electron will have enough energy to move to the surface of the electrode and it will then be 'ejected from' that electrode, yielding an electric current. The conduction electrons are bound to the constituting atoms of the electrode with less energy, so it is easier to knock them lose.
These electrons are the valence (ie the outer electrons) electrons of the constituting atoms. When you put many atoms together, their wavefunctions (more specifically, their orbitals) will overlap and this yields a 'continuous' region over the atom-lattice, that can be occupied by these electrons. they are not localized to one atom but they can move 'freely' over the entire atomic-lattice.
regards
marlon
Thank yo marlon. :smile:
If photocells lose electrons in the process of use, they get old from too much light knocking off electrons. Correct? Because photcells lose more and more electrons the longer they are used, they get more postively charged he longer they're in use? Do photocells last long enough or have lasted longe enough to experience these things?
That is a good question, though i don't really know the exact answer. Clearly , you will need some kind of battery to 'refresh' the photo-cell.
Perhaps somebody else will know more on this...Again good question though
regards
marlon
I think this is a question for ZapperZ :wink:
regards
marlon
OK, ok.. I'll step in...
The semiconductor is usually grounded, meaning it is being replenished with electrons that either were photoemitted, or the ones that got "conducted" away. If not, you will have charging effects on the cell and it will stop functioning, because the effective work function will just build up due to charge depletion.
Zz.
Ok, so , does this mean that a photo-cell reaches saturation ( at one point, the rise of the power of the bulb-light which lights the cell does not rise the intensity of the current produced by the photo-cell anymore ) because it is not perfectly grounded ?
I worked with a device which was supposed to measure the power of various laser diodes using a photo-cell.It was very unpleasant that there was a maximum power that the device was able to measure.
If it is done continuously, yes, it is entirely possible. Or, you have a rather inefficient diode with very few charge carrier density. Or the bias voltage to detect photocurrent isn't large enough, etc, etc. It depends on the photocell, and what KIND it is.
Either way, most manufacturers will indicate the working range of any photocell. And this is not just with respect to power, but also what freq. range, what temperature, etc...
Zz.
Thanks ZapperZ.
  • · Replies 58 ·
9K
