What is the relationship between voltage and current in a capacitor circuit?
  • Thread starter Thread starter Clari
    Capacitors
The discussion revolves around the relationship between voltage and current in a capacitor circuit, particularly focusing on the behavior of these quantities over time as represented in V-t and I-t graphs. Participants are exploring the implications of a sine wave voltage input on the charge and current in the circuit.
  • Participants are attempting to sketch graphs for charge and current based on the voltage behavior. Questions are raised about the relationship between voltage changes and current flow, particularly during different phases of the voltage cycle.
Some participants are providing guidance and clues regarding the behavior of current in relation to voltage changes, while others express confusion about specific concepts and the implications of their sketches. There is an ongoing exploration of how the current behaves as the voltage transitions through its cycle.
Participants are grappling with the concept of phase differences between voltage and current, as well as the implications of the current reaching zero at certain points in the cycle. There is a noted uncertainty about how to accurately represent these relationships in their graphs.
Clari
Hi there!
I have great problem in tackling some problems on this topic, I hope you can help me. :confused:
1. For a V-t graph, it has the shape of a sine curve but well beyond the x-axis. It has 3 complete cycle in 6ms as shown in the graph.
Notes: V is the potential difference applied between the terminals in a circuit varies with time t.
a. Sketch a graph of how the charge on the capactior changes over 6ms.
I sketch it the same as the V-t graph, since Charge (Q) = CV...Q is proportional to V. Am I right?
b. Sketch a graph of the current in this circuit, marking clearly on this graph the I=0 value.
I have thought of it for quite a long time, but can't figure it out yet.. :cry:
I have attached the document which have the graph.
a. yes
b.Some clues:
Take the first 90 degrees of the voltage cycle. As the voltage increases from zero towards its maximum, what will the current do?
Over next 180 degrees, the voltage at the supply is reducing in comparison to the capacitor to a lower threshold, so the capacitor will have a greater PD then the supply that needs to correct itself. The voltage reduces slowly then drops at speed then slows down when it reaches the bottom threshold again. So, imagine what the currrent will be doing, when the voltage is changing slowly will the current be large or small, when the voltage is dropping fast, what will the current be doing?
Delta,Thank you very much for helping out. :)
But I don't really get what you mean by
Delta said:
...The voltage reduces slowly then drops at speed then slows down when it reaches the bottom threshold again. "...
Here are my answers to your guiding questions:(lol, I am not sure if it is correct)
Over the first 90 degrees of the voltage cycle, as V increases from 0 to max., the current drops from max. to 0. Over next 180 degrees, the voltage at the supply is reducing in comparison to the capacitor. So the current flows in the opposite direction until the voltage rises again...
umm...But I am frustrated about the I=0 value, if I draw the I-t graph silimilar to the V-t graph(not in phase), then I will never be 0. :frown:
"The voltage reduces slowly then drops at speed then slows down when it reaches the bottom threshold again."
From V=maximum (at 90deg) the voltage falls slowly therefore will the current be high or low?
When V is half way to its lowest value, there is larger rate of change widening the potential between the supply and capacitor, therefore will the current be high or low?
at V=minimum (at 270deg) the voltage changes more slowly as it reaches the lower part of the wave, so would the current now be high or low?
Note when I say "low" I mean close to zero and "high" means a larger current in either direction. Up to you to work out if its is positive or negative current (charging/discharging...?).
Good.
therefore the current will be positive or negative?
... bit of a key concept here
Once the voltage has settled to a maximum or minimum value the capacitor is the same as the supply, therefore there is no PD between the two. Would there be in current?
  • · Replies 30 ·
