Simple Harmonic motion problems
The discussion focuses on solving simple harmonic motion problems, specifically analyzing the equations for x(t) and y(t). The equation for x(t) is established as x(t) = A*cos(wt + ϕ) + C, where initial conditions x(0) = 0 and v(0) = 0 lead to the conclusion that C = 0. The phase angle ϕ is determined to be either 0 or π, resulting in the final equation for x(t) as A*cos(wt). The y motion is confirmed to be described by A*sin(wt), demonstrating the relationship between the two motions.
  • Understanding of simple harmonic motion concepts
  • Familiarity with trigonometric functions and their properties
  • Knowledge of calculus, specifically differentiation
  • Ability to interpret initial conditions in motion equations
  • Study the derivation of simple harmonic motion equations
  • Learn about the role of phase angles in oscillatory motion
  • Explore the relationship between sine and cosine functions in harmonic motion
  • Investigate applications of simple harmonic motion in real-world scenarios
Students studying physics, educators teaching mechanics, and anyone interested in mastering simple harmonic motion problems.
ness9660
http://sweb.uky.edu/~lsadam0/problem2.JPG
Im kinda lost on this problem. Shouldnt the Y motion be described as A*sin(wt)?
In there equation we are considering when x=0, so the kx term is removed, but where is this third term coming from, and then should Y motion just be described as Asin(-wt-o)?
Nope,unless,at t=0 the amplitude is zero.Nope,the III-rd term is called "initial phase" and should not be missing when writing the general solution.
Daniel.
Thank you for sharing this problem. Simple harmonic motion problems can be tricky, but with some practice and understanding of the concepts, they can be easily solved.
First, let's break down the given equation for x(t):
We can see that the amplitude (A) and the angular frequency (w) are given. The phase angle (ϕ) and the constant (C) are yet to be determined.
Now, looking at the problem, we are given the initial conditions: x(0) = 0 and v(0) = 0.
Plugging in t=0 in the given equation, we get:
x(0) = A*cos(0 + ϕ) + C
Since x(0) = 0, we can conclude that C = 0.
Next, we need to determine the phase angle (ϕ).
Using the given initial velocity (v(0) = 0), we can find ϕ by differentiating x(t) with respect to time:
v(t) = dx(t)/dt = -A*w*sin(wt + ϕ)
Plugging in t=0, we get:
v(0) = -A*w*sin(0 + ϕ) = 0
This means that sin(ϕ) = 0, which gives us ϕ = 0 or ϕ = π.
Now, we can rewrite the equation for x(t) as:
x(t) = A*cos(wt)
And for the y motion, we can use the same equation with a different phase angle:
y(t) = A*cos(wt + π) = -A*cos(wt) = A*sin(wt)
Therefore, the y motion can be described as A*sin(wt).
I hope this explanation helps you understand the problem better. Keep practicing and you will become more comfortable with solving simple harmonic motion problems!
  • · Replies 51 ·
