Gravity and Work: Understanding the Relationship between Force and Motion
  • Thread starter Thread starter rwh
    Gravity Work
The discussion revolves around the concept of work in physics, specifically in relation to the force of gravity acting on a bowling ball rolling along a bowling alley. Participants explore why gravity is said to do no work in this scenario despite its presence.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants examine the definition of work and its relationship to force and displacement, questioning the conditions under which gravity does or does not perform work. Some discuss the implications of gravitational force being perpendicular to the motion of the bowling ball.
The conversation includes various interpretations of the question posed by the original poster, with some participants providing clarifications on the distinction between gravity acting on the ball and the work done by gravity. There is an ongoing exploration of the principles involved, particularly regarding the angle between force and motion.
Participants note that the bowling alley is typically flat, which influences the discussion about the work done by gravity. There is also mention of the role of friction in the context of gravitational force acting on the bowling ball.
rwh
I have a question that is probably pretty basic. On a test my teacher gave he asked the following question:
Why does the force of gravity do no work on a bowling ball rolling along a bowling alley?
I answered:
I disagree with this statement. The bowling ball has mass so gravity is acting on the bowling ball proportionally to its mass. Just because the bowling ball is on a slippery surface where there is little friction does not mean that the law of universal gravitation does not apply. So gravity is working on the bowling ball while it is rolling along the bowling alley.
The correct answer was:
the direction of the force of gravity is perpendicular to the motion no work
This is an online class and I copied every thing directly. Where is my reasoning wrong? And what principles did I forget?
Thanks for your help,
rwh
well the definition of work is
W = force [in the direction of movement] * displacement.
if gravity is acting straight down and the bolwing ball is moving perfectly horizontally, then to get the force in the direction of movement,
F*cos(90) = 0, so there is no force being aplied in the direction of movement.
this is similar to the fact that if you are holding a heavy weight in your arms, and the weight is not being lifted or lowered, then no work is being done on it, although the person holding it may argue differently, since there is no movement/displacement, no work.
If work is done to the ball, it would gain energy (ie it would speed up or gain potential energy).
Work is defined as:
[tex]W = \int \vec F \cdot d\vec{s}= \int cos\theta mgds[/tex]
where [itex]\theta[/itex] is the angle between the gravitational force and the direction of the object's motion. If that angle is 90 deg, cos 90 = 0 so the work done is 0.
If the floor is sloped, the work done by gravity would be non-zero. But most bowling alleys are pretty flat.
AM
Basically, as the ball is rollign down the alley, gravity is not playing any part in the ball's energy state (relative to the ground). Therefore gravity does no work.
Because it has no component in the direction of the ball... hey perpendicular to each other and thus independent. But on the other hand the weight gravity applies on the alley causes friction.
rwh said:
I answered:
I think part of the confusion is that you understood the question as asking "why doesn't gravity act on the bowling ball". And, given that interpretation, you answered correctly that of course gravity acts on the bowling bowl. But the question was about the work done by the force of gravity, which has a specific meaning in physics. As others have explained, the work done by the gravitational force is zero in this case.
So, in a sense, gravity certainly "works" on the bowling ball (it pulls the ball downward), but it does no work (in the physics sense) on the ball. Everyday words often have precise technical meanings in physics. Beware!
  • · Replies 28 ·
  • · Replies 20 ·
