Calculus Max. and Min. Question
  • Thread starter Thread starter laker_gurl3
    Calculus Max
The problem involves maximizing the area of a rectangular swimming area using a fixed length of rope along a shoreline. The original poster presents two scenarios: one without restrictions and another with a distance constraint from the shore.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the correct interpretation of the problem, clarifying that the area is rectangular rather than triangular. They explore how to express the dimensions in terms of a variable and how to derive the area function for maximization.
Some participants have provided guidance on setting up the problem and expressing the area in terms of a variable. There is an ongoing exploration of how to maximize the area based on the constraints given, with no explicit consensus on the final dimensions yet.
Participants note the need to correct the problem statement and clarify the relationship between the dimensions of the rectangle and the total length of rope available. The additional constraint regarding the distance from the shore is also under discussion.
laker_gurl3
The lifeguard at a public beach has 400m of rope available to lay out a rectangular restricted swimming area using the straight shoreline as one side of the triangle.
a.) If she wants to maximize the swimming area, what will the dimensions of the rectangle be?
b.)To ensure the safety of the swimmers, she decides that nobody should be more than 50m from shore. What should the dimensions of the swimming area be with this added restriction?...
What do i doo?
A is supposed to be 100m by 200m..and b is 50m by 300m...i can't get those at all though!
First, repair the statement of your problem. The area is in the shape of a rectangle, not a triangle
a) Three sides of the rectangle are formed by the rope. Let x = the length of the side parallel to the shore. Figure out how to express the other two sides in terms of x. Express the area of the rectangle in terms of x. Maximize that area. You will need the derivative of the area set equal to zero.
b) This is a simple calculation based on your expression of the area in terms of x. What is the value of x in this case?
oops yah ur right, the last word of the problem should have been rectangle..
The rectangle has sides a,a,b,b.Okay?From the text of the problem u're given that
[tex]2a+b=400[/tex] and you're asked about the values of "a" and "b" to maximize the area,i.e.the product [itex]a\cdot b[/itex].
From the constraint,u find that [itex]b=400-2a[/itex] and so the area function which needs to be maximized becomes
[tex]S=a(400-2a)[/tex]
Find "a" for which the function S is maximum...
Daniel.
