How Does Heavy Hydrogen Affect the Wavelength of the Balmer Series?
The discussion revolves around calculating the difference in wavelength for the first line of the Balmer series in ordinary hydrogen compared to heavy hydrogen. The original poster mentions specific masses for both types of hydrogen and provides the known wavelength for ordinary hydrogen.
  • The original poster attempts to calculate the wavelength for heavy hydrogen but is struggling to achieve the expected difference. Some participants suggest considering the effects of the center of mass on energy levels and wavelengths, while others reference the Bohr model and the role of reduced mass in the calculations.
Participants are exploring the implications of mass differences on wavelength calculations, with some guidance offered regarding the Bohr model and reduced mass. The original poster indicates they have reached a resolution, but the details of that resolution are not shared.
The original poster is working within the constraints of a homework problem, which may impose specific requirements on the calculations and assumptions about the systems involved.
pi-r8
Ok, for this one problem, I'm supposed to figure out the difference in wavelength between the first line of the Balmer series in ordinary hydrogen (M= 1.01 u) and in "heavy" hydrogen (M = 2.01 u). The balmer series is when the lowest n is 2, by the way. I already know that the wavelength for the first line of the series in ordinary hydrogen is 656.1 nm, but the answer to this question is supposed to be 0.178 nm, and I can't figure out any way to calculate a wavelength for heavy hydrogen that would give a difference that small. It seems like, no matter what I do, I keep getting half the wavelength of regular hydrogen. Anyone know what to do on this one?
The change in wavelength would be very small because a "heavy hydrogen" nucleus has the same charge as a normal hydrogen nucleus, so it exerts roughly the same force on the electron. However, the center of mass of the electron-nucleus system will change. Can you see how this might effect the energy levels (and thus, the wavelengths)?
Check out the Bohr model and you will see that the electron mass plays a role in the energy level.
But the mass to use is the reduced mass mer=me.mp/(me+mp).
As you can see the change in mer is very small as mp/(me+mp) is nearly 1 as for both cases mp=1.01 or 2.01 as me = 1/1800 mp.
Using the Bohr model you will get a good indication of the magnitude of the deviation
Thanks guys! I got it.
