How can I estimate the fatigue life of a component subjected to a rotating cam?
The discussion focuses on estimating the fatigue life of a cantilever component subjected to a rotating cam with a 10mm offset at 230 RPM. The user has calculated the peak acceleration (A) using the formula A = a(sqr w), where 'a' is the cam offset and 'w' is the angular frequency. Additionally, static stresses, including principal stress (σ) and maximum shear stress (τ), have been determined at the fixed end of the cantilever. To proceed with fatigue life estimation, it is essential to compare the alternating stress against S-N diagrams specific to the material of the beam.
  • Understanding of basic mechanics and dynamics
  • Familiarity with fatigue analysis and S-N curves
  • Knowledge of static stress calculations (principal stress and shear stress)
  • Ability to perform simulations related to mechanical components
  • Research S-N diagrams for the specific material used in the cantilever
  • Learn about fatigue limit and its implications for material selection
  • Explore advanced fatigue analysis methods, such as the Goodman relation
  • Investigate simulation tools for dynamic loading scenarios, such as ANSYS or SolidWorks
Mechanical engineers, materials scientists, and anyone involved in fatigue analysis of mechanical components will benefit from this discussion.
chandran
I am working on a physics problem in a project to estimate fatigue life of a component.
There is a cam rotating with an offset of 10mm rotating at an rpm of 230. The component is a cantilever fixed at one end is getting hit by this cam while it is rotating. The cam is at the other end of cantilever.
I want to simulate this using basic mechanics to estimate the fatigue life of the component. So far i have done the following
1.peak acceleration due to the component is a(sqr w) where a is the cam offset and w is the frequency of rotation of cam. Call this peak acceleration as A
2.I have calculated the static stresses(principal stress(sigma) and maximum shear stress(tau)) at the cantilever point(fixed end) due to a load of P as sigma
After that how should i proceed to check the fatigue life?
First thing you can do is to take your alternating stress and compare that to what can be found in S-n diagrams for the material your beam is made out of. That I would think would be the quickest and easiest. If your material has a fatigue limit, you will find it there.
19K
