Solving Corrosion & Heat Transfer Problems on Steel Vat Plated with Zinc
The discussion focuses on addressing corrosion rates, heat transfer, thermal stresses, elastic and plastic deformation, hydrogen build-up, and failure time for a steel vat plated with zinc used to store sulfuric acid. Key resources include the NACE Corrosion Wiki for corrosion rates, the Engineering Toolbox for heat transfer calculations, and the Diffusion Equation Calculator for diffusion problems. Understanding the concentration and temperature of sulfuric acid, along with the properties of zinc plating, is crucial for accurate assessments. The discussion emphasizes breaking down the problem into manageable parts to facilitate understanding and problem-solving.
  • Understanding of corrosion rates in zinc and sulfuric acid
  • Knowledge of heat transfer principles and thermal conductivity
  • Familiarity with elastic and plastic deformation concepts
  • Basic understanding of hydrogen solubility and diffusion in metals
  • Research corrosion rates of zinc in sulfuric acid
  • Learn about heat transfer calculations using the Engineering Toolbox
  • Study elastic and plastic deformation principles related to structural integrity
  • Explore hydrogen diffusion in metals using the Diffusion Equation Calculator
Students, engineers, and researchers dealing with materials science, corrosion engineering, and thermal analysis, particularly those focused on the interaction between metals and corrosive environments.
omagdon7
I have a problem that I need to solve that is quite extensive it boils down to this. I have a steel vat that's been plated with zinc and its being used to store sulfuric acid. I have to find corrosion rates, heat transfer and thermal stresses, elastic and plastic deformation problems, hydrogen build up and diffusion, and the amount of time till the thing finally fails and steel meets acid.
My teacher was horrible I have no idea where to start and this seems like an unreasonable assignment since it accounts for half of my grade and I have 2 days. Any suggestions hints or links to sights that explain the concepts herein would be appreciated.
Unfortunately, in two days it will be impossible to get a full understanding of all the concepts you need to solve this problem. However, there are some resources you can use to help you understand the concepts and apply them to your problem. For corrosion rates and hydrogen build up, you can find information on the NACE Corrosion Wiki page (https://www.nace.org/corrosion-wiki/). Here, you can find information about different types of corrosion and their effects.For heat transfer and thermal stresses, you can reference the Heat Transfer section of the Engineering Toolbox (https://www.engineeringtoolbox.com/heat-transfer-d_429.html) which has a range of equations and diagrams you can use to calculate these values. You can also reference the website Wolfram Alpha (https://www.wolframalpha.com/) which can provide answers and graphs to help with elastic and plastic deformation problems. Additionally, you can use the Diffusion Equation Calculator (https://www.omnicalculator.com/physics/diffusion-equation) to help with diffusion problems.Finally, for the amount of time till failure, you will need to develop a model of your system and use engineering principles to make an estimate. You can reference this article from Engineering Toolbox (https://www.engineeringtoolbox.com/failure-modes-d_1226.html) to help with understanding how to approach this part of the problem.I hope these resources help you! Good luck!
Hello,
I understand that you are facing a difficult and extensive problem with your steel vat plated with zinc. It is understandable that you are feeling overwhelmed and unsure of where to start. I would suggest breaking down the problem into smaller, more manageable parts and tackling them one at a time.
First, let's start with the corrosion rates. This will depend on the concentration and temperature of the sulfuric acid, as well as the composition and thickness of the zinc plating. You can research the corrosion rates of zinc in sulfuric acid and use that as a starting point.
Next, for heat transfer and thermal stresses, you will need to consider the temperature of the sulfuric acid and the surrounding environment, as well as the thickness and thermal conductivity of the steel and zinc layers. This will help you determine the rate of heat transfer and potential thermal stresses on the vat.
For elastic and plastic deformation problems, consider the weight of the sulfuric acid and the structural integrity of the steel vat. You can research the yield strength and modulus of elasticity of the steel and use that to calculate any potential deformations under the weight of the acid.
Hydrogen build-up and diffusion can also be a concern, as hydrogen can cause embrittlement in steel. Research the solubility of hydrogen in sulfuric acid and its potential diffusion into the steel vat.
Lastly, the time until failure will depend on the rate of corrosion and any potential structural issues caused by the sulfuric acid. You can use the information gathered from the previous steps to estimate the time until the steel meets the acid.
I understand that this is a challenging assignment and that you have limited time to complete it. I would recommend seeking help from classmates or a tutor if possible. You can also refer to online resources or textbooks on corrosion and heat transfer for a better understanding of the concepts involved.
I hope this helps and wish you the best of luck in completing your assignment. Don't hesitate to reach out for further assistance.
