Is a Continuous and Periodic Function Bounded and Uniformly Continuous on R?
  • Context: Graduate
  • Thread starter Thread starter steven187
    Continuity
The discussion revolves around the properties of continuous and periodic functions, specifically whether such functions are bounded and uniformly continuous on the real numbers. Additionally, a second problem regarding the continuity of a function defined by specific functional equations is also addressed.
  • Homework-related
  • One participant, Steven, seeks assistance in proving that a continuous and periodic function is bounded and uniformly continuous, expressing uncertainty about how to begin the proof.
  • Another participant suggests that proving boundedness is simpler than proving uniform continuity and questions how the periodic nature of the function aids in the proof.
  • It is noted that any continuous function on a closed interval is uniformly continuous, prompting a discussion about the implications of periodicity.
  • Steven proposes that if uniform continuity is shown on one period, it could extend to all intervals due to the periodic nature of the function.
  • In the second problem, participants discuss the implications of the functional equations provided and the conditions needed to prove continuity at every point, with one participant emphasizing the importance of the definition of continuity at a point.
  • A later reply provides a structured approach to show continuity at any point using the hypothesis of continuity at zero, suggesting a change of variables to facilitate the proof.
Participants generally agree on the foundational concepts of boundedness and uniform continuity for continuous functions, but there is no consensus on the specific role of periodicity in the proofs. The second problem remains unresolved as participants explore different approaches to proving continuity.
Participants express uncertainty regarding the necessity of the periodic condition in the first problem and the implications of the functional equations in the second problem. There are also unresolved mathematical steps in the proofs discussed.
This discussion may be useful for students and practitioners interested in the properties of continuous functions, particularly in the context of periodicity and functional equations in mathematics.
steven187
hello all,
i have been working on problems with continuity and i have come across some question in which i understand generally what i have to do but i just don't know where to start and how to put it together
a function f:R->R is said to be periodic if there exists a number k>0 such that
f(x+k)=f(x) for all x an element of R. suppose that f:R->R is continuous and periodic. Prove that f is bounded and uniformly continuous on R.
also
let f:R-->R be a function which satisfies the conditions
f(x+y)=F(x)+f(y)
and
f(-x)=-f(x) for al x znd y an element of R
suppose that f is continuous at 0 show that f is continuous at every point in R
please help
Steven
Smells like homework. First problem is peculiar in that proving "bounded" is far simpler than proving "uniformly continuous". If you are working with "uniformly continuous" you should long ago have seen the proof that any continuous function (you don't need "periodic") is bounded. In order to prove uniformly continuous you will need to use the fact that a function continuous on a compact set (here, closed and bounded) is uniformly continuous. Do you already know that? How does "periodic" help you there?
For the second problem, I don't see why they include "f(-x)=-f(x) for all x and y an element of R". That follows from "f(x+ y)= f(x)+ f(y)". Any way: What is the DEFINITION of "continuous at 0" ?? Now what conditions must be met to prove "continuous at a"?
continuity
your right every continuous function is bounded i just thought that there would be more to it to actually show it, and in terms of the uniform continuity so you are saying anythin on a closed interval and bounded and continuous will prove that f is uniformly continuous ,i can see that but we havnt actually used anythin about the periodic function, without the periodic function concept the question does not sound that complicated if i had to use the concept of the periodic function then from my understanding so far is that if i prove that it is bounded and uniformly continuous on an interval [0,k] which is the length of the period then i would be able to prove it for all intervals say [nk,nk+k] (where n is a positive intiger) since it is a periodic function does that sound right,
about the second problem, do you mean : if we choose epsilon>0 then there will be delta such that !x!<delta then !f(x)!<epsilon but i don't know how that follows on to prove that it is continuous at a also
[tex]\forall \epsilon >0 , \ \exists \delta \ \ s.t. \ \ |x|<\delta \Rightarrow |f(x) - f(0)|< \epsilon[/tex]
This is the hypothesis. You got to use that to show that
[tex]\forall \epsilon >0 , \ \exists \delta \ \ s.t. \ \ |x-a|<\delta \Rightarrow |f(x) - f(a)|< \epsilon[/tex]
I suggest making the change of variable x - a = y. Then what we want to show now is that
[tex]\forall \epsilon >0 , \ \exists \delta \ \ s.t. \ \ |y|<\delta \Rightarrow |f(y+a) - f(a)|< \epsilon[/tex]
but f(y+a) = f(y)+f(a), and f(a) = f(a+0) = f(a) + f(0), so
[tex]|f(y+a) - f(a)|< \epsilon \Leftrightarrow |f(y) + f(a) - f(a) - f(0)|< \epsilon \Leftrightarrow |f(y) - f(0)|< \epsilon[/tex]
But this is precisely the statement of the hypothesis. So it's true and we won.
  • · Replies 18 ·
