Thought experiment that shows hor the 3rd principle fails on spirals
The discussion revolves around a thought experiment involving a cannonball attached to a cable, exploring the implications of tension in circular and spiral motion. Participants examine the dynamics of the system, questioning the application of Newton's third law in the context of spirals, and the relationship between tension and the trajectory of the ball. The scope includes theoretical reasoning and conceptual clarification regarding forces and motion.
  • One participant describes a scenario where a cannonball is shot horizontally and attached to a cable, questioning how tension affects its motion and trajectory.
  • Another participant simulates the scenario and provides numerical results, suggesting that lower tension leads to an outward spiral while higher tension results in an inward spiral.
  • Some participants propose that the tension in the cable directly influences the type of spiral motion, with lower tension resulting in outward spirals and higher tension causing inward spirals.
  • There is a contention regarding the application of Newton's third law, with some arguing that it fails in the context of spirals, while others assert that the law remains valid.
  • A participant mentions the historical context of the discussion, referencing Schauberger's ideas about spirals and free energy, suggesting a connection to the current thought experiment.
  • Several participants express confusion about the mechanics involved, particularly regarding the forces acting on the cannonball and the implications for Newton's laws.
Participants do not reach a consensus on the validity of Newton's third law in the context of spirals. Multiple competing views remain regarding the relationship between tension, motion, and the principles of physics involved.
Participants note the neglect of gravity and other forces in their analysis, which may limit the applicability of their conclusions. The discussion also highlights the complexity of the forces involved and the assumptions made in the thought experiment.
aviator
im in a 10 m tower, a 1kg cannonball is shot underneath me horizontally at 10 m from me and I am holding a cable that is tight to the ball, for the ball to make a circle the tension shown in a dinamometer put in the cable would be v*v*m/r= 1000N being the speed of the ball 100 m/s
i shoot the ball again and this time i let the cable slip or glide away in my hands in such a way that the tension shown is 100 N, let's neglect transformation of friction into heat, gravity and cable weight
how long will it take the ball to reach my horizontal?
what radius will have the cable when the ball is at my horizontal?
when the ball is at my horizontal going to my vertical what constant tension would show the dinamometer if when the ball reached my vertical had to have 10 m radius again by my having pulled the cable?
how long will it take it to reach my vertical?
the cable is pulled or let away by crancking the cable(rigid in this case) and the spinning axe in such a way that for every grade the axe spins the cable retracts or spands one meter or whatever necesary
Well Aviator I am not quite sure about the question and do not really know how to solve this in pure maths . For the first part since you eliminated gravity and whatnot
I translated this to the horizontal plane and assumed your vertical occurred when the ball has moved by 90 degrees rotation . I assumed just 100N tension , 1 kgm mass
and an initial velocity of 100 m/s. Then I simulated the whole lot with very small time steps in QBasic . My answer was about 0.64 seconds .I also got an answer for the distance at that time it was 48.3 meters .
The second I got ~10.4 meters at 180 degrees rotation. vertical
My simulation correctly gives a circle at 1000n force
but at 100n yields precessing elipses , the rope being both let out and pulled in again.
I would rather like to see your approach and what exactly you meant by the original question . I.E. whether I am correct or not What principle has been broken and why .
Yours Ray. :smile:
my point is that if you have the ball spinning with a certain tension in the cable so it makes a circle and suddenly you apply a minor tension the ball will make a spiral for a while, if you aply a bigger tension than the one necesary to make a circle it will start making an inwards spiral
therefore if the ball makes an outwards spiral the tension will be lower that if it makes an outwards spiral
this seems obvious to me and i must be really bad explaining it since i can't convince nobody that the principle of action reaction fails on spirals :zzz:
before i meant that in an inwards spiral the tension is bigger than in the simetrical outwards spiral
How can you suppose it will make a circle around you? You only talk about a horizontal velocity. In order to make a circle it needs a perpendicular velocity. Explain.
by aplying a tension on the cable of v*v*m/r the horizontal v becomes circular now
if you aply a tension minor it makes an outwards spiral if you aply atension bigger it makes an inwards spiral
therefore 3rd principle fails on spirals if you take two quarters of simetrical spirals one inwards and the other outwrds like in the cannon example you get un upwards force that have no reaction
In the case you think the ball will rise to your level it is not matter of force. It is matter of iniritia. As the radius becomes larger, the angle between radius and cable decreases and Y component decreases as well. Eventually, the angle and the Y component will both be equal to zero when the ball will rise to your level.
If I am not talking about the right thing I would like to explain more precicly. Do you pull the cable in upward direction, or sideway?
it took me quite long to understand it myself
if you accept that by aplying a tension of v*v*m/r the ball will make a circle (neglecting gravity) what trouble do you have accepting that if you aply a tension lower than that one it will make a spiral? (eventually the spiral will end in a circle when the 100N tension applied is equal to v*v*m/r ending in a circular trajectory where the radius makes the v*v*m/r equal to the aplyied tension)
you can't figure this out by using vectors since the use of vectors implies the aceptance of reaction as undiscusible while I am trying to prove a case in which there's no reaction, i would say that vectors fail in this case as well as the 3rd principle
the way the ball is let away or pulled in is by crancking with gears the spinning axe with the pull or let away of the cable which in this case would be rigid
you can simply transform the horizontal velocity of the ball into vertical velocity by simply tighting the cable to an axe which would keep spinning and reversing linear momentum forever if there was no friction
Your example is unclear (at least to me). For some reason, you seem to believe that Newton's 3rd law is being violated. Please start over and clearly state what forces you think are involved in your example and why you think Newton's 3rd law is violated.
a cannonball is shot horizontally 10 m under my vertical and is tight to an axe(me) with a cable, the tension (pulling force) is kept for the first quarter of spin in 100 N, so the radius of the cable grows
in the second quarter i aply a tension to the cable bigger than 100N, such force that the cable radius now shrink
the trajectory in the first quarter is simetrical to the trajectory in the second quarter and no extra energy is aported to the ball so the speed of the ball is the same in the first quarter than in the second
if i have a tension that pulls the axe down with a force of 100 N during let's say 1 second and a force of let's say 1000N pulling up during 1 second also the result is a pull of 900N up during one second
this that I am saying is very old the first to discover the reactionles properties of spirals was schauberger
what I am trying is to give explanation to schauberger ideas
i would have given up this 4 years old idea if it wasnt because schauberger also said that this spiral stuff leads to free energy
i think the main point of my idea is that the ball if with a tensionof 500N makes a circle with more or less tension makes an inwards or outwards spiral
spiral that eventually ends in a circle as well when the radius and tension (force) adjust to satisfy the formula v*v*m/r=F
if there's anything i can do for this to be understood better just let me know
if you are spining around you a ball tight to a cable at a constant speed and in the middle of the cable there's a dinamometer that shows the tension
when the dinamometer shows 500N the ball is making a circle
if you want the dinamometer to show 100N without varying the speed of the ball you let the cable glide away in your hand in such a way that the ball makes an outwards spiral, now the dinamometer shows 100N, eventually when the radius is big enough it won't grow any more and the ball will end making a circle
if you want the dinamometer to show 1000N you have to pull the cable at the same time you spin it in such a way it makes an inward spiral, eventually the ball ends in the center of the axe spinning with no tension in the cable
is not that i believe the 3rd principle to fail i see it failing
schauberger would have said about the 3rd principle failing how is it posible that I am the only one to see it and i feel now just the same
I'm still not getting what all this has to do with Newton's 3rd law. If the cable pulls on the cannonball with a force X, then the cannonball will pull on the cable with the same force, oppositely directed.
Free energy? I don't think so! :smile:
Why not leave gravity out of it and have your ball move along a frictionless table? But if you are pulling and releasing a cable, even this problem may be difficult to analyze. But I see no basis for a violation of Newton's 3rd law or free energy.
(I see this is all coming from the ideas of Viktor Schauberger, who, as far as I can see was quite the crackpot. Don't waste your time.)
if the ball is spinning in a circle and the axe is floating in space in the first quarter the ball will pull the axe down with a force of 500N and in the second quarter will pull up with a force of 500 N so the axe will vibrate in space being pulled each time with a force of 500N forever if there was no friction. The axe doesn't remain stationary it moves in oposite direction to the ball
but in my example this eternal bivration (if there was no friction) is of 100N down and 1000N up so it vibrates acelerating upwards
you are getting thrust without giving away mass nor holding on anything but empty space
in the first quarter the ball pulls on the axe 100 N in the second it pulls 1000N
so in the first quarter the axe pulls on the ball 100N and in the second it pulls 1000N
maybe 3rd principle is not violated but still this idea shows the posibility of building an engine that would produce thrust without giving away any mass
by the way either the universe is eternal and has no beginning or energy-matter is created from nothing or even both because of nothing there's infinite
said with another words the pull when the ball is above the axe is of 1000 N and when is below of 100N
aviator said:
...this idea shows the posibility of building an engine that would produce thrust without giving away any mass...
No it doesn't. It shows the possibility of building a device that will flop around like a beached salmon.
most probably my idea will flop
but first at least i try for free energy like tesla, joseph newman or john hutchinson
second i don't take scientific data as matter of faith i think by myself
there's no diference between a person who takes physics principles as matter of faith and afghans who take the wearing of burka by women as undiscusiblle because of being a milenary matter of faith, older than Newtons principles
im like an afghan who thinks by himself instead of using faith an says hey maybe the burka is wrong and people will say are you crazy this is milenary
You forgot one other possible option - that your ignorance of what you have is causing you to think that you have something new. How can you tell if what you have is new when you don't know what is known already?
I think both chronos and doc al have been rather "generous" in their comments. I, on the other hand, will not. I've seen several of your postings claiming this and that, and now I will tell you why I think this thing IS a flop based on your faulty understanding.
The clearest example of this is the fact that you are just picking on JUST the 3rd Law? Now why is that? Are you saying that your "experiment" doesn't violate Newton's 1st and 2nd Law, just the 3rd?
This is where you show your ignorance. ANY physics student worth his/her salt can tell you that Newton's 1st, 2nd, and 3rd Laws are really just ONE law or description. They are not 3 different things, but rather the SAME thing but under different circumstances. What this means is that you can't violate one without violating the others!
Secondly, have you ever re-read what you have written? I'll be the first to admit that I make typos all the time and my sentence structure can run on and on and on... but really, c'mon now! Go look at the way you are trying to present your idea and tell me if you think it makes any sense!
Third, Joe Newman? Puhleeze! If his machines truly work, he would have produced something by now! Go read Bob Park's book "Voodoo Science" where he has shown you the details on why this guy is a quack.
But the most important issue in all of this is the very same question I have asked all quacks both on here and ever since I bump into the first of them on the 'net back in 1989 (yes, I've been "connect" THAT long): What makes you think that you have understood the subject matter THAT much to be able to challenge it?
You haven't made anything to show that it works. All you have is simply something in your head that you are convinced violates something you barely understand. And if you think you're ... er.. "special", you're not! We get one of these very often, and there are more of you on Crank Dot Net that are making even MORE outrageous claims, and frankly, more entertaining quackeries than you.
Zz.
P.S. I'm recommending that this thread by shoved into the TD section.
this is not new
schauberger was beaten to death after he visited the usa for these ideas on spirals
clem died after he sold his spirals engine to the general electrics the very next day
tesla got many patents clasified as secret maybe they were free energy as well
the nazis work in an space time bending project called the bell that were two counterotatory cylinders just like the engine i deviced that now i try to explain its functioning
joseph newman says the electrons move in an atom in inwards and outwards spirals just like the cannonball of my idea and like newman I am unable to hold property of the patent, first for having a psicotic episode the very same week the patent got published which unable me to take posesion of the patent and secondly for having a second psicotic episode the very same week i try to recover posesion of the patent, certainly i won't go for a third so i forget the patent
this makes sense if we take in consideration the 400 witness of the disclosure project that say that the biggest secrets in this moment are extraterrestrial life free energy and antigravity they also say that tesla discovered both antigravity and free energy but is kepts secret ever since
i have already said i was wrong my idea doesn't violate the 3rd principle because the principles don't say that you can't produce aceleration without giving away mass although most people interpret them this way, my engine acelerates without giving away mass i think
english is my second language so I am not very clear but if you don't understand something i say you just have to ask me and ill be more than pleased to answer you
joseph newman machine has been avalated by 20 engineers
do you think that if free energy was discovered would it be made public?
so gold has the same value than plumb, petrol is valueless as well and the poor countries become rich suddenly breaking the balance between poor and rich
my understanding might be better than most peoples because i don't believe anything, i must understand it by myself while most people has some principles they take as a matter of faith and therefore undiscusible
i think the best and less risky way to take this away is by convincing smarter people than me that can prove my ideas right like frolov the russian physicist that believes that gyroscopes of varying radius like mine produce thrust
i believe myself to be special as special as everybody else since there are not two equal persons, everybody is new
certainly my ideas prove me a crackpot but that doesn necesarily mean I am wrong just that I am able to accept any idea as posible however weird is it
  • · Replies 17 ·
  • · Replies 75 ·
  • · Replies 28 ·
  • · Replies 17 ·
13K
