What is the proof of the Bolzano-Weierstrass Theorem?
  • Thread starter Thread starter courtrigrad
    Point
The Bolzano-Weierstrass Theorem asserts that any bounded infinite subset of \(\mathbb{R}^n\) contains at least one accumulation point. The discussion clarifies that while each sub-interval can contain an infinite number of points, it is not limited to just one accumulation point. The concept of point of accumulation is defined as an interval around the point that contains infinitely many points from the set. The intersection of sub-intervals can also contain an accumulation point, particularly as their diameters approach zero.
  • Understanding of the Bolzano-Weierstrass Theorem
  • Familiarity with concepts of accumulation points and bounded sets
  • Knowledge of real analysis, specifically \(\mathbb{R}^n\)
  • Basic comprehension of intervals and neighborhoods in topology
  • Study the formal proof of the Bolzano-Weierstrass Theorem
  • Explore the concept of accumulation points in metric spaces
  • Learn about locally sequentially compact spaces in real analysis
  • Investigate the properties of intersections of intervals in topology
Mathematicians, students of real analysis, and anyone interested in understanding the foundational concepts of accumulation points and the Bolzano-Weierstrass Theorem.
courtrigrad
I was just reading about the point of accumulation. Is it right in saying that given any sub-interval, that atleast one of these could contain ani infinite amount of points? Also why couldn't all the sub intervals contain an infinite amount of points? I came across the following: [tex]0.a_{1}a_{2}[/tex] (where a1 and a2 are sub-intervals) must be the point of accumulation. I do not understand the following statement. Is it because its a decimal?
Thanks a lot :smile:
"given any sub-interval, that atleast one of these could contain ani infinite amount of points" What do you mean by "at least one of them"? One of what? The definition of "point of accumulation (of a set of points) is that there exist an interval (more generally neighborhood) of the point that contains an infinite number of points in the set. Of course, I is an interval about "point of accumulation" P, any sub-interval of I, that also contains P, must also contain an infinite number of point in the set.
"I came across the following: [tex]0.a_{1}a_{2}[/tex]
(where a1 and a2 are sub-intervals) must be the point of accumulation. I do not understand the following statement."
What "following statement"? You don't give any "following statement".
As far as [tex]0.a_{1}a_{2}[/tex] is concerned, I don't know what that could mean if "a1 and a2 are subintervals" rather than digits! Are you sure you copied it correctly?
This sounds like the proof of the Bolzano-Weierstrass Theorem
Any bounded infinite subset of [itex]\mathbb{R}^n[/itex] has an accumulation point.
There is nothing prohibiting all the subintervals from having an infinite number of points in common with the set. Note that the theorem doesn't suggest that the set has ONE and ONLY one accumulation point, just that there is at least one.
As for the second part of your statement, I think what is intended is the INTERSECTION of the subintervals. This is nonempty ( although this is a slightly nontrivial conclusion - it requires you to know that the reals are locally sequentially compact ). None-the-less, since the original set has an infinite number of points in common with each subinterval ( chosen in accordance with the proof of the Bolzano-Weierstrass Theorem ), and any neighborhood of the intersection will contain one of the subintervals ( as the diameter of the subintervals get smaller at the rate of [itex]2^n[/itex] ) - then any neighborhood of the interesection of the subintervals therefore has infinitely many points in common with the original set. In otherwords, the intersection contains an accumulation point ( and in this case, there is one and only 1 in the interesection because the diameter of the subintervals goes to 0 )
I hope that wasn't too confusing, I was trying to avoid getting into specifics. If it will help to do so, let me know.
  • · Replies 25 ·
  • · Replies 22 ·
