Can I Use a 60 Watt Bulb in a "40 Watt Max" Fitting?
The discussion centers around the safety and implications of using a 60-watt bulb in a light fitting rated for a maximum of 40 watts. Participants explore the potential risks, including heat generation and electrical considerations, as well as the practical outcomes of such a choice.
  • One participant questions whether a 60-watt bulb would operate safely in a 40-watt max fitting, suggesting that it may not reach its full brightness due to power limitations.
  • Another participant emphasizes that the primary concern is heat generation, noting that a 60-watt bulb produces more heat than a 40-watt bulb, which could lead to safety issues.
  • A different viewpoint suggests that removing the globe could mitigate fire risks when using a higher wattage bulb.
  • One participant provides a detailed electrical analysis, explaining the differences in resistance and current flow between the two bulb types, and raises concerns about potential damage to wiring and fittings due to increased current and heat.
  • Another participant expresses a decision to purchase 40-watt bulbs instead, indicating a preference for adhering to the manufacturer's recommendations.
Participants express differing opinions on the safety and practicality of using a 60-watt bulb in a 40-watt fitting. While some highlight the risks associated with heat and current, others suggest that it may not cause immediate harm. No consensus is reached regarding the safety of this practice.
Participants mention various assumptions, such as the voltage supply and the specific resistance values of the bulbs, which may affect the discussion's conclusions. The impact of initial current and the potential for damaging fittings are also noted but remain unresolved.
Civilian2
Gday,
This is a very simple question and it should only take one sentence to answer. It's not worthy of these forums, lol, but despite my efforts I cannot find an answer through google.
If a light fitting says '40 watt max' and I stick a 60 watt bulb in it, will that have any adverse effects? I assume what will happen is that only 40 watts of power will be fed into the bulb thus not fulfilling the bulbs potential brightness, but I'm unsure and thought I better ask before I do it.
Thanks in advance.
No, it's a heat consideration. A 60-watt bulb generates more heat than a 40-watt bulb, and if you use it you'll be putting more heat into the globe than it is designed to handle. You'll still get the same light output from the 60-watt bulb that it would give in any other circumstance.
KM
If you want to use a larger wattage bulb, leave the globe off. Otherwise you might have a fire problem.
Thanks for your response. I'll simply go and buy some 40 Watt bulbs, lol.
Assume you have a 120volt supply. The bulb resistance will cause a particular current to flow ([tex]I=V/R[/tex]) and this will result in a certain amount of power being dissipated ([tex]P=VI=V^2/R[/tex]). This means that a 40watt bulb has a specific resistance resistance ([tex]R_{40W}=V^2/P=120^2/40=360\Omega[/tex]) and that the resistance of the 60W bulb is different ([tex]R_{60W}=V^2/P=120^2/60=240\Omega[/tex]). The 60W bulb will cause ([tex]I_{60W}=V/240=0.5 Amps[/tex]) to flow, compared with ([tex]I_{40W}=V/360=0.33 Amps[/tex]).
The fitting doesn't know the difference, but it is possible that the difference in current could damage light wiring or that the extra heat could damage plastic fittings. A more significant effect depends on the cold resistance of the bulbs (before they are turned on) because this determines the initial current. The higher wattage bulb has lower hot resistance and so probably has lower cold resistance. The higher starting current may cause you to blow more bulbs.
It probably won't hurt (I have just replaced a 25W bulb with a 60W bulb because that was all I could get) but if you are the careful sort then follow the manufacturer's directions.
11K
  • · Replies 152 ·
12K
12K
