Simultaneous non-linear equations
  • Thread starter Thread starter HallsofIvy
    Non-linear
The discussion revolves around solving a system of simultaneous non-linear equations: x + y = 5 and x^x + y^y = 31. Participants are exploring the nature of the problem and the potential methods for finding solutions.
  • Participants suggest finding positive integer solutions for the equations, with some proposing to substitute variables to simplify the problem. Others question the correctness of the equations as presented and discuss the implications of different interpretations, such as considering negative values for x and y.
The conversation includes various approaches to the problem, with some participants offering hints and guidance on how to proceed. There is a mix of suggestions regarding numerical solutions and the use of specific mathematical functions, but no consensus has been reached on a definitive method or solution.
There is an emphasis on finding integer solutions, and some participants express uncertainty about the applicability of certain methods, such as the Lambert W function, given the original poster's level of understanding. Additionally, the possibility of negative solutions is raised, indicating a need for a broader exploration of the problem.
HallsofIvy
abi ubong said:
hey i was given this at school anD can't do it its a simul eqn. x+y=5,x^x+y^y=31.
This was sent to me as a personal message- it's always better to post questions like this than just send them to me!
abi ubong, hint:
Try to find all positve integer solutions to your system;
that is what I think your teacher is after!
1.So, your first job is to determine:
Which pairs of positive integers (x,y) satisfies the equation: x+y=5
2. Then, you must determine: Which of those pairs you found under 1. also satisfy [tex]x^{x}+y^{y}=31[/tex]
Are you certain you copied this correctly? x+y= 5, x2+ y2= 31 would be very easy, x+ y= 5, xx+ yy= 31 is very hard!
The obvious thing to do is write the first equation as y= 5- x and substitute into the second equation: xx+ (5-x)5-x= 31. You might be able to put this into a form you could apply the "Lambert W function" to, but that's certainly not elementary. Other than that, I would suggest a numerical solution.
Arildno got in before me- his suggestion: look for positive integer solutions reduces the possible solutions so it can be done by direct computation.
Assuming, of course, that there are positive integer solutions!
I aint' proud. Am I helping out too much? Really, I didnt' even know to check for integers until I gave up and scrolled down to Arildno's post. Anyway, the plot is for:
[tex]y(x)=x^x+(5-x)^{5-x}-31[/tex]
Just to add something in regard to saltydog's post (I hope he'll agree with me on this):
abi ubong:
The roots of saltydog's FUNCTION Y(x) will give you the NUMBERS x in the NUMBER PAIRS (x,y) which are solutions to your system.
The corresponding NUMBERS y is found by the equation y=5-x, where x is a root for Y(x).
i still do not get any of this especially urs hallsofivy wats rthe lambert w function or watever it is ,plssssssssssssss i need graet help
Well, since you evidently haven't bothered to read my reply to you, don't expect anymore help on this.
abia ubong: The "Lambert W function" is the inverse of the function f(x)= xex. It can be used to solve many equations in which x is both an exponent and a base.
However, if you are not in college, you probably would not be expected to know that function. Look at "salty dog"'s and "arildno"'s responses!
Look again at arildno's first suggestion. If x and y have to be positive integers AND their sum is 5, the only possibilities are:
x= 1, y= 4
x= 2, y= 3
x= 3, y= 2
x= 4, y= 1
Do any of those satisfy xx+ yy= 31?
hey firstly do not get offended arildno,also hallsofivy wat if x or y or maybe both were 2 be negative,such methods might not work i need a general solution .
thnxs
  • · Replies 20 ·
  • · Replies 29 ·
  • · Replies 21 ·
