Prove that a set is a monoid, but not a ring.
  • Context: Graduate
  • Thread starter Thread starter grimster
    Ring Set
The discussion revolves around proving that the set End n(k) of all polynomial mappings from k^n to k^n forms a monoid, while also demonstrating that it does not qualify as a ring. The focus includes theoretical aspects of algebraic structures, specifically properties of function composition and the definitions of monoids and rings.
  • One participant asserts that they need to prove End n(k) is a monoid by showing that composition is associative and that there is a unit element.
  • Another participant questions the necessity of proving associativity, suggesting it is a basic result of function composition.
  • There is a discussion about whether the composition of mappings F and G in End n(k) remains in End n(k), with some participants finding this self-evident.
  • Participants explore the criteria for End n(k) not being a ring, particularly focusing on the failure of distributivity.
  • One participant expresses uncertainty about how to formally prove associativity and the closure of composition within End n(k).
Participants generally agree that composition is associative and that End n(k) has a unit element, but there is uncertainty regarding the necessity of proving these properties. The discussion about End n(k) not being a ring is less clear, with different viewpoints on the implications of distributivity.
Some participants express uncertainty about the proofs required for associativity and closure under composition, indicating a potential lack of clarity on foundational definitions or prior knowledge. The discussion does not resolve whether all necessary properties for a ring are satisfied.
Readers interested in algebraic structures, particularly those studying properties of monoids and rings, may find this discussion relevant.
grimster
End n(k) is the set of all polynomial mappings: k^n->k^n. i have to prove that end n(k) is a monoid.
k is a field of q elements and n is the number of variables.
the composition of two mappings F G is: F o G = F o G(v) = [F1(G1(v),..Gn(v)), ... Fn(G1(v),...Gn(v))]
i must prove that the composition is associative and that there is a unit element.
id=X=(x1,...,xn) is obviously the unit.
but how do i prove associativity? i was thinking of using commutativity somehow:(x^n)^m = x^(n*m) = x^(m*n) = (x^m)^n
last, how do i show that End n(k) is not a ring? is it distributivity it fails? for all x,y,z E A ->
(x+y)z=xz + yz og z(x+y)=zx + zy
You should already know that!
I presume you mean with composition as the multiplicative operation?
Well, if it's not a ring, and all of the other properties are satisfied, then it would have to be!
i guess it is obvious that composition is associative, but I'm not sure how to prove it.
and yes, composition is the multiplicative operation.
Associativity is a basic result about the composition of functions -- it shouldn't be something you have to prove.
But if you really want to do it, simply use the definition of composition.
hm, ok. so i guess then i have to show that if F and G is in End n(k), then so is F o G in End n(k). however, this seems pretty obvious to me. how do prove that? is there a elegant proof of this?
You always had to prove the composition of two things in End n(k) was again in End n(k) -- I had assumed you had already done that, or I would have said something.
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 25 ·
