Why Is Sqrt(3) Used in Calculating VRMS for Triangle Waves?
The discussion revolves around understanding the use of sqrt(3) in calculating the VRMS (Root Mean Square Voltage) for triangle waves, contrasting it with the sqrt(2) used for sine waves. Participants are exploring the mathematical foundations and qualitative reasoning behind these formulas.
  • Conceptual clarification, Mathematical reasoning
  • Participants are attempting to articulate a qualitative reason for the use of sqrt(3) in the context of triangle waves, with some discussing the integration of the waveform and its implications on the RMS calculation. Others are questioning the relationship between the crest factor and the RMS values for different waveforms.
The discussion is ongoing, with participants providing hints and partial insights into the mathematical process involved in calculating VRMS. Some guidance has been offered regarding the integration method and the relationship between the squared values of the waveforms, but no consensus has been reached on a definitive qualitative explanation.
Participants are working under the constraints of providing a succinct qualitative explanation while grappling with the mathematical derivations involved in RMS calculations for different waveforms.
StonieJ
I feel like I'm so close to the correct answer for this problem, but I just can't seem to bring it all together.
Code:
To find the V[sub]RMS[/sub] of an AC sine wave, you use the following
forumla, where V[sub]max[/sub] is the maximum amplitude:
V[sub]RMS[/sub] = V[sub]max[/sub] / sqrt(2)
To find the V[sub]RMS[/sub] of an AC triangle wave, you use:
V[sub]RMS[/sub] = V[sub]max[/sub] / sqrt(3)
In one sentence, give a good qualitative reason why sqrt(3) is appropriate
for the triangle wave.
I have a bunch of vague and un-elegant ideas, but not really one good sentence. I've been Googling on the subject and coming up with crest factor (peak / RMS), which is sqrt(3) for triangle waves and sqrt(2) for sine waves. But I have yet to bring it all together. Any help is appreciated.
You need to integrate the square of the wave form over one period and divide by the integration interval to find the mean square. Then you take the square root.
because in the triangle wave, V is proportional to t... and V^2 is proportional to t^2, when you do the RMS, you need to take the squreroot of [tex]\int V^2 dt[/tex], this is where the root 3 come from
Hint:
The method for calculating the "crest factor" is simple:
1) Square the function under consideration. (That's the "square" part of the term "root mean squared.")
2) Average that squared function over time; one period is enough. (That's the "mean" part.)
3) Take the square root of the result. (That's obviously the "root" part.)
For the sine wave, the RMS multiplier is thus:
[tex]\sqrt{\frac{\int_0^{2 \pi} \sin^2 x dx}{2 \pi}} = \frac{1}{\sqrt{2}}[/tex]
To come up with an elegant sentence, first, recognize that [itex]1/\sqrt{3}[/itex] is smaller than [itex]1/\sqrt{2}[/itex]. Next, graph the squared triangle wave superimposed over the squared sine wave. Notice that the squared sine wave is always equal to or greater than the squared triangle wave. Thus, its time average is correspondingly larger.
- Warren
26K
22K
  • · Replies 21 ·
  • · Replies 38 ·
10K
