How Do Electrical Forces Interact in Physics Problems?
This discussion focuses on the calculations of electrical forces using Coulomb's Law and gravitational forces using Newton's Law of Universal Gravitation. Key formulas include Fe = kQq/R² for electrical force and Fg = GMm/R² for gravitational force. The calculations provided yield results such as 3.6 x 1010 N for electrical force and 7.80 x 10-47 N for gravitational force. The importance of considering the direction of forces and the nature of charges (positive or negative) is emphasized throughout the discussion.
  • Coulomb's Law for calculating electrical forces
  • Newton's Law of Universal Gravitation
  • Understanding of charge (positive and negative) and its relation to electrons
  • Basic algebra for manipulating equations and solving for unknowns
  • Study Coulomb's Law in detail, including its applications and limitations
  • Explore the concept of charge-to-mass ratio for electrons
  • Investigate the implications of force direction in electrical interactions
  • Learn about real-world applications of electrical and gravitational forces in physics
Students of physics, educators teaching electrical forces and gravitation, and anyone interested in understanding the fundamental interactions of charged particles.
seiferseph
I have some more questions from a physics worksheet, this time on electrical forces. here are the questions and the answers i got, thanks in advance!
Questions:
http://i2.photobucket.com/albums/y15/seiferseph/electircalforces.jpg
Answers:
1) Fe = kQq/R^2, i get 3.6 x 10^10 N
2) a) Fg = GMm/R^2, i get 7.80 x 10^-47 N
b) Fe = kQq/R^2, using 1.6x10^-19 for both Q and -1.6x10^-19 for q, i get Fe = -8.86x10^-8 N
3) Q = n*e, Q/e = n. n = 2.5x10^19. i have a question though, can it be negative? (the charge is negative)
4) How do i do this one? is it just a simple ratio problem?
5) a) i calculated the force of each one separately, i used 2*1.6x10^-19 for the charge of the middle one, because it has two protons.
F 1 on middle = k*q1*qmiddle/R^2 = 3.2x10-16
F 2 on middle = k*q2*qmiddle/R^2 = 1.44x10-15
and i get 1.76x10^15 N to the right
b) F = m*a, F/m = a, where m is 4*1.67x10^-27 = 2.6x10^11 m/s^2
thanks!
Questions:
Answers:
thanks!
1) 2) Correct approach.. did not check your computations
3) The negative charge comes from negatively charged electrons. The NUMBER of electrons is positive.
4) Yes. You can find the charge to mass ratio for one electron.
5) a) Are these forces in opposite directions?
b) There is no b showing
1) Your calculation for the electrical force between the two charges is correct. However, it is important to note the direction of the force, which would be repulsive in this case since both charges are positive. So the correct answer would be 3.6 x 10^10 N to the right.
2)a) Your calculation for the gravitational force is correct. However, it is important to note that this is a very small force due to the extremely small masses of the particles involved.
b) Your calculation for the electrical force is also correct. Again, it is important to note the direction of the force, which would be attractive in this case since one charge is positive and the other is negative.
3) Your calculation for the number of electrons is correct, and yes, the charge can be negative in this case since it represents the charge of an electron.
4) For this question, you can use Coulomb's Law to calculate the electrical force between the two charges. Simply plug in the values given for Q and q, and then solve for the force.
5)a) Your calculations for the electrical forces are correct. However, when adding them together, it is important to consider the direction of the forces as well. Since both forces are to the right, the total force would be 1.76 x 10^15 N to the right.
b) Your calculation for the acceleration is correct. However, it is important to note that this is an extremely high acceleration, which is not likely to occur in real-life situations.
Overall, your calculations and answers are correct. Just make sure to pay attention to the direction of the forces and to use the correct values for the charges in your calculations. Keep up the good work!
  • · Replies 16 ·
