Bicycle Shox Dynamics: Velocity & Acceleration Measurement
  • Context: Undergrad
  • Thread starter Thread starter chandran
    Bicycle Dynamics
The discussion revolves around the dynamics of bicycle shock absorbers, specifically focusing on how to measure velocity and acceleration at various points on a bicycle when a person of weight 100kg is seated. The conversation touches on basic dynamics theory and the application of mechanisms in this context.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that knowledge of the spring constant and conservation of energy might be necessary to determine velocity and acceleration, although they express uncertainty about their correctness.
  • Another participant proposes that the system can be analyzed as a four-bar mechanism, indicating that velocities and accelerations can be calculated using the instantaneous centers method.
  • A request for resources or websites that explain how to find accelerations and velocities in a four-bar mechanism is made, but no specific resources are provided.
  • A follow-up request reiterates the need for guidance on methods for calculating accelerations and velocities in a four-bar linkage, indicating a lack of available information.
Participants express differing views on the methods to be used for calculating velocity and acceleration, with no consensus reached on a specific approach or solution.
Participants mention the need for specific parameters such as the spring constant and the load transfer due to rotation, which may not be fully defined in the discussion.
chandran
Please go thro the link. it shows an animation of bicycle shox.
http://www.santacruzmtb.com/vpp/. click on the animation
Suppose a person of weight 100kg sits on this how can i know the
velociy,accelerations at various points on the bicycle. Can any
basic dynamics theory help in this?
i may be wrong but you'd probably need the the spring constant ... use conservation of energy ... also need to know how the load is being transferred due the rotation ... i know I'm wrong but i gave it a shot
Don't we have a four bar mechanism there. If that is the case u can calculate the velocities and accln using the instantaneous centers method
burnhard,
Any website for showing method to find accelerations,velocity in four bar mechanism?
chandran said:
burnhard,
I am sorry I do not know of any good website which shows the methods to find accelerations and velocities in a Four bar linkage. Maybe someone out there can help.
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 23 ·
15K
