How Do I Solve These Systems of Differential Equations with Specific Conditions?
  • Thread starter Thread starter Tarhead
    System
This discussion focuses on solving systems of differential equations, specifically determining the intervals of gamma for stable focus and stable node in the equation x' = [(-3)(gamma)]x + [(6)(4)]x. The eigenvalue analysis reveals that there are no values of gamma that yield a stable node or stable focus due to the positive real part of the eigenvalues. Additionally, the second problem involves periodic solutions for the system x' = [0 3]x + [-12 0] with initial conditions x1(0)= 1, x2(0)= 2, leading to a solution with a period of T = 1/6.
  • Understanding of eigenvalues and eigenvectors in linear algebra
  • Familiarity with stability criteria for differential equations
  • Knowledge of periodic solutions in differential equations
  • Proficiency in solving characteristic equations
  • Study the stability criteria for linear systems of differential equations
  • Learn about eigenvalue analysis in the context of differential equations
  • Explore periodic solutions and their characteristics in systems of differential equations
  • Investigate the application of the Routh-Hurwitz criterion for stability analysis
Students and professionals in mathematics, engineering, and physics who are working with systems of differential equations and require a deeper understanding of stability and periodic solutions.
Tarhead
I am having problems with solving systems of differential equations.
x'= [(-3 ) (gamma)]x
...[ ( 6 ) ( 4 ) ]
I am supposed tofind the interval of values of gamma for a) stable focus and b) stable node.
I started by
[(-3-r) (gamma)][x1] = [0]
[( 6 ) (4-r ) ][x2]...[0]
det(A-rI) = (-3-r)(4-r)-6(gamma) = 0
= r^2-r-12-6(gamma)= 0
but I don't know where to go after this point to find these different intervals.
For another problem:
x'= [0 3]x
...[-12 0] with initial conditions x1(0)= 1, x2(0) = 2
show that the solution x(t) is periodic and determine its period. Additionally to find the moment(s) when the point x(t) is closest to the equilibrium point 0.
For this I have
[(-r ) (3)][x1] = [0]
[(-12) ( -r)][x2]...[0]
so r^2 + 36 = 0
how do I or do I factor this? and after I find my values of r and plug them back in, where do I go?
for the first problem,
a) I'm going to assume stable focus means stable spiral... that occurs when you have complex roots and real part is negative
b) stable node occurs for real eigenvalues < 0 and det A (your system) is > 0
your book should have a section on stability criteria w/ critical parabola diagram. you just look at different regions of the graph to determine eigenvalues <-> phase portrait. qualitatively, i think its clear your real part of eigenvalue should be negative to obtain a stable solution. you can't have a exp(+rt) to be stable as t->infinity.
i'm learning diff eq myself and i haven't learned periodic solutions yet.. so can't help you w/ second problem.
...[ ( 6 ) ( 4 ) ]
I started by
x'= [0 3]x
For this I have
so r^2 + 36 = 0
SOLUTION HINTS:
Problem #1:
Given following system of differential equations:
[tex]1: \ \ \ \ \ \left [<br /> \begin{array}{r}<br /> x_{1}^{'} \\<br /> x_{2}^{'} \\<br /> \end{array}<br /> \right ] \ \, = \ \, \left [<br /> \begin{array}{rr}<br /> -3 & \gamma \\<br /> 6 & 4 \\<br /> \end{array}<br /> \right ] \left [<br /> \begin{array}{r}<br /> x_{1}(t) \\<br /> x_{2}(t) \\<br /> \end{array}<br /> \right ][/tex]
Determine eigenvalues "λ":
(-3 - λ)*(4 - λ) - 6*γ = 0
::: ⇒ λ2 - λ - 6(2 + γ) = 0
::: ⇒ λ = (+1/2) ± (1/2)*sqrt{1 + 24*(2 + γ)}
STABLE NODE occurs when BOTH "λ" solutions are real and NEGATIVE. There are NO VALUES of "γ" for which this is true for both "λ"s because of the "(+1/2)" first term above.
STABLE FOCUS occurs when both "λ" solutions are COMPLEX (α ± βi) with NEGATIVE real "α". There are NO VALUES of "γ" for which this is true because of the "(+1/2)" first term above.
Problem #2:
[tex]2: \ \ \ \ \ \left [<br /> \begin{array}{r}<br /> x_{1}^{'} \\<br /> x_{2}^{'} \\<br /> \end{array}<br /> \right ] \ \, = \ \, \left [<br /> \begin{array}{rr}<br /> 0 & 3 \\<br /> -12 & 0 \\<br /> \end{array}<br /> \right ] \left [<br /> \begin{array}{r}<br /> x_{1}(t) \\<br /> x_{2}(t) \\<br /> \end{array}<br /> \right ][/tex]
λ2 + 36 = 0
::: ⇒ λ = ±(6i)
::: ⇒ x(t) = exp{±(6i)*t}
::: ⇒ x(t) = cos(ω*t) ± i*sin(ω*t) where ω = 2*π*f = 6
Determine period "T" of sinusoidal solutions "x(t)" using relationship between frequency "f" and "T", which is {T = 1/f}.
  • · Replies 24 ·
  • · Replies 40 ·
  • · Replies 42 ·
