How Do You Calculate Temperature and Pressure in Isentropic Compression?
  • Thread starter Thread starter bruce999
    Exam Revision
The discussion focuses on calculating temperature and pressure during isentropic compression in a spark ignition engine. For pure air with constant specific heat, the final temperature and pressure can be determined using the equation T2/T1 = (P2/P1)^((γ-1)/γ), where γ is 1.4. For a stoichiometric mixture of air and octane (C8H18) with variable specific heats, the specific heat ratio (γ) must be calculated based on the mole fractions of the components before applying the same isentropic compression equation. Accurate unit management and formula verification are essential for successful calculations.
  • Understanding of isentropic processes in thermodynamics
  • Familiarity with the ideal gas law and specific heat ratios
  • Knowledge of stoichiometric calculations for fuel mixtures
  • Proficiency in using thermodynamic equations for temperature and pressure
  • Study the isentropic compression equation in detail
  • Learn how to calculate specific heat ratios for gas mixtures
  • Review the ideal gas law and its applications in thermodynamics
  • Practice problems involving temperature and pressure calculations in engines
Students preparing for thermodynamics exams, engineers working with spark ignition engines, and anyone interested in understanding isentropic processes in gas mixtures.
bruce999
Exam revision question. Help!
Hello.
I have a thermodynamics exam tomorrow. This is a past exam question and I'm not doing very well with it. If anyone has any ideas please help!
A charge enters a spark ignition engine at 330K and 1 bar, and is isentropically compressed through a ratio of 7:1. Estimate the temp and pressure at the end of the compression, taking the charge to be:
a) pure air with constant specific heat.
b) a stoichiometric mixture of air and octane(C8H18) with variable specific heats (neglect residual gases). :eek:
For part a: you will use the constant specific heat relationships. They are something like P1/P2 = (V2/V1)^k-1 note: That equation is probably not true, but the three formulas are in that same format. Knowing that compression ratio is V1/V2, you can easily plug that number into the formula given initial T and P to find final T and P.
for b: hmmmm...partial pressures and stuff...wow, I have no idea. I guess one would find the stoichiometric ratio, I believe it's ~14:1, then go from there. That's about all the help I got for that part.
Hi there,
I can understand the stress and pressure of preparing for an exam, especially when facing a challenging question. Don't worry, I am here to help!
For part a), you can use the isentropic compression equation to solve for the final temperature and pressure. This equation is T2/T1 = (P2/P1)^((γ-1)/γ), where T is temperature, P is pressure, and γ is the ratio of specific heats (1.4 for air). You can plug in the given values and solve for T2 and P2.
For part b), you will need to use the specific heat ratio (γ) for a mixture of air and octane, which can be calculated using the mole fractions of each component. You can then use the same isentropic compression equation to solve for the final temperature and pressure.
Remember to pay attention to units and double-check your calculations. Also, make sure to review any relevant formulas and concepts before the exam. Good luck!
17K
  • · Replies 33 ·
9K
