Understanding Photon Detection: Solving a Problem with Starlight
  • Thread starter Thread starter Reshma
The discussion revolves around a problem involving photon detection from a distant star, specifically focusing on the number of photons that reach the human eye from a star emitting a large number of photons per second. The context includes concepts from astrophysics and optics, particularly regarding visible light and the geometry of light propagation over astronomical distances.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore how to calculate the number of visible photons that reach the eye from a star 1200 light years away, considering the star's isotropic emission of photons and the geometry of light propagation. Questions arise about the area of the spherical surface at that distance and how it relates to the area of the pupil.
The discussion is active, with participants providing insights into the calculations needed to determine the number of photons hitting the eye. Some participants have offered clarifications on the geometric relationships involved, while others have questioned assumptions about the distribution of photons and the necessary calculations to find the answer.
There are mentions of specific values and assumptions, such as the diameter of the pupil and the total number of photons emitted by the star, which are critical to the calculations but are still under discussion. The original poster expresses uncertainty about how to proceed with the problem, indicating a need for further exploration of the concepts involved.
Reshma
I seem to have a problem understanding this problem let alone solving it:frown:
A star emits 2x1045 photons per sec, 80% of which are in the visible range. The star is 1200 light years away, and the night adapted eye, whose pupil makes an opening 4mm in diameter, can barely see the star. How many photons per sec are necessary to trigger the eye as a detector?
I figured out the number of photons in the visible range is = 0.8x2x1045
Can someone help me proceed?
Out of those photons, how many will go to a surface of known area a given distance away?
Reshma,
2E45 is a lot of photons, right? What do you think the problem means when it says the star emits that many photons/second? What are you picturing?
Thank for looking into this-Jdavel and Galileo.
Jdavel-I'm picturing the number of visible photons here, but few will be detected by the night adapted eye.
Galileo- are you referring to the surface area of the pupil?
The 2E45 photons form a shape... they are burst by the star every second.
What is the area of the shape when photons reach 1200 light years away.
Can you use the area of this shape and the area of the eye to calculate how many of the 2E45 photons hit the eye?
That is the required number of photons per second.
OK, the distant star is a sphere and HERE you take the radius(R) as 1200 light years, right? Using this assumption:
R=1.14x1019m. Area is given by [tex]4 \pi R^2[/tex]
Can you clarify this?
Also area of puplil [tex]A= \pi (2\times 10^{-3})^2[/tex]
I would suppose that the elementary flux model we use will give the answer here: you know the fraction f of the total number of photons emitted by the source (N). A light year is the distance traveled by light at a velocity 299792458 m/s in vacuum in one year (which means a LOT of seconds: 86400s/day * 365 days or if you want to be ultraprecise (you can't be) then its 365.25 days). The source gives out fN photons per second but the source is apparently isotropic so it gives out fN photons over a spherical region of space. If you "cut in" somewhere with some radius r then the effective area over which the fN photons are "available" completely is [itex]A_{T}=4\pi r^2[/itex] so the number of photons arriving at the eye is actually [itex]\frac{fN}{A_T}A_{eye}[/itex]. Whats wrong with that? :shy:
In addition to reading the above comments, you may want to check out this thread.
Yes. Looks right.
(area of eye)/(area of sphere) = (no.visible photons that hit eye)/(total number of visible photons)
I made a mistake in my previous post. Be sure to use 1.6E45 (visible photons) instead of 2E45.
The number of visible photons that hit the eye is what you're looking for.
Thanks for the help everyone. My final answer is: 12 visible photons per sec hit the eye.
SpaceTiger- Thank you so much for the link. Your post was extremely well written and gives me a clear picture in context to this question.
  • · Replies 0 ·
12K
