Ethers0n
- 27
I'm attempting to use Matlab to help me solve a controller design problem...
I'm using the Polynomial Equations Approach for this design, but I'm getting an error, and a result I wasn't looking for.
I'm getting an error that reads "Warning: Matrix is singular to working precision."
Also, the last Matrix M is returning the values NaN for all values...
My code is bellow. Any help would be appreciated
%Servo Position Controller
%Using Polynomial Equation Method
%Defining the vairables in the TF
Rm = 2.6; %armature resistance
Km = 0.00767; %Back-emf constant
Kt = 0.00767; %motor torque constant
Jm = 3.87*exp(-7); %motor moment of inertia
Jeq = 2.0*exp(-3); %equivalent moment of inertia at the laod
Beq = 4.0*exp(-3); %equivalent viscous damping coefficient
Kg = 70; %srv02 system gear ratio (motor->load) (14X5)
Ng = 0.9; %gearbox efficiency
Nm = 0.69; %motor efficiency
a0 = Jeq*Rm %defining the terms of plant denominator
a1 = (Beq*Rm + Ng*Nm*Km*Kt*(Kg)^2)
a2 = 0;
b0 = Ng*Nm*Kt*Kg %defining terms of plant Numerator
PlantNum = [b0] %plant numerator
PlantDenom = [a0 a1 a2] %plant denominator
PlantTF = tf(PlantNum, PlantDenom); %building the plant transfer function
%because a second order system is desired (from the lab handout)
%the closed loop poles will be at s^2 + 2s + 1 ie at +-45 degrees from the
%axis...
E = [a2, 0, 0, 0; %the Sylvester Matrix E for a plant with the equation
a1, a2, 0, 0; %like this (0*s^2) + (0*s) + X
1, a1, b0, 0; % ---------------------
0, 1, 0, b0;] % (z*s^2) + (y*s) + w
% D = F*H, D = (s^3) + (2s^2) + s + 0 = (d0*s^3)+(d1*s^2)+(d2*s)+d3
% D = [d3
% d2
% d1
% d0]
D = [0;
1;
2;
1;]
M = (inv(E))*D %inverting the Sylvester Matrix and multiplying by D
%this gives the coefficients which will produce the desired
%controller...
% M = [alpha1
% alpha0
% beta1
% beta0]
%The dseired controller is of the form
% beta0 + beta1 Beta(z)
% alpha0 + alpha1 Alpha(z)
a2 = 0;
%axis...
% D = [d3
% d2
% d1
% d0]
D = [0;
1;
2;
1;]
%controller...
% M = [alpha1
% alpha0
% beta1
% beta0]
