Calculate Angular Frequency for Damping Motion with Mass-Spring System
The discussion focuses on calculating the angular frequency of a damped mass-spring system with a natural angular frequency (w_n) of 3.6 rad/s. The amplitude is reduced to 0.35 times its initial value over 12.9 seconds, leading to the need for the damping coefficient (c) and mass (m) to determine the damped angular frequency (w_d). The relevant equations include w_d = w_n * sqrt(1 - (c/2m)^2) and the amplitude ratio equation A/A_0 = e^(-ct/2m). The discussion emphasizes the importance of these calculations for understanding the dynamics of damped harmonic motion.
  • Understanding of damped harmonic motion
  • Familiarity with the equations of motion for mass-spring systems
  • Knowledge of logarithmic functions and their application in physics
  • Basic principles of oscillation and angular frequency
  • Study the derivation and application of the damping coefficient in mass-spring systems
  • Learn how to calculate the spring constant (k) using natural frequency
  • Explore the relationship between amplitude decay and damping in oscillatory systems
  • Investigate the effects of varying damping coefficients on system behavior
Students and professionals in physics, mechanical engineering, and applied mathematics who are interested in the dynamics of oscillatory systems, particularly those involving damping effects in mass-spring systems.
evgeniy
A mass spring with natural angular frequency w= 3.6rad/s is placed in an environment where there is a damping force proportional to its speed. If the amplitude is reduced to 0.35 times its initial value in 12.9 s, what is the angular frequency of the dampin motion?
Can anyone help out with an equation that i should use?
It seems there is not enough info, like what is the velocity of the spring?
y(x=0,t) = Acos(w*t)?
since I know time and A.
Thanks...
Thanks...
The answer to this is in the same place as another question I just encountered
http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html
To calculate the angular frequency of the damping motion in this scenario, we can use the equation:
where w_d is the angular frequency of the damping motion, w_n is the natural angular frequency of the mass-spring system, c is the damping coefficient, and m is the mass of the object.
In this case, we are given the natural angular frequency (w_n = 3.6 rad/s) and the time it takes for the amplitude to decrease (t = 12.9 s). However, we still need to determine the damping coefficient (c) and the mass (m) in order to solve for w_d.
To find the damping coefficient, we can use the information that the amplitude is reduced to 0.35 times its initial value. This means that the amplitude ratio (A/A_0) is 0.35, where A_0 is the initial amplitude.
We can use the equation for amplitude ratio in a damped mass-spring system:
A/A_0 = e^(-ct/2m)
Plugging in the given values, we get:
0.35 = e^(-c*12.9/2m)
Solving for c, we get:
c = -2m * ln(0.35)/12.9
Now, we need to determine the mass (m). We can use the fact that the natural angular frequency is given by:
w_n = sqrt(k/m)
where k is the spring constant. We can rearrange this equation to solve for m:
m = k/w_n^2
We are not given the spring constant, but we can find it using the given information that the amplitude is reduced to 0.35 times its initial value. We can use the equation for amplitude in an undamped system:
A = A_0 * cos(w_n*t)
0.35 = cos(3.6*12.9)
Solving for A_0, we get:
A_0 = 0.35/cos(3.6*12.9)
Now, we can use the equation for spring constant:
k = m*w_n^2
Plugging in the values for m and w_n, we get:
k = 0.35/cos(3.6*12.9) * (3
