Help with Constant Acceleration Lab
The discussion focuses on solving a physics lab problem involving constant acceleration, specifically determining the initial velocity (Vo) and maximum height (dy) of a thrown ball. The lab requires measuring the time the ball is in the air during two different trials: throwing and hitting with a tennis racket. The participant is advised to utilize equations of motion, such as Vf=Vo+at and d=1/2(Vf+Vo)t, while considering the acceleration due to gravity at -10 m/s². The key to finding Vo lies in understanding the relationship between the time of ascent and total time measured.
  • Understanding of basic kinematics and equations of motion
  • Knowledge of gravitational acceleration (-10 m/s²)
  • Ability to perform basic algebraic manipulations
  • Familiarity with experimental data collection and analysis
  • Study the equations of motion for constant acceleration in detail
  • Learn how to derive initial velocity from time of flight
  • Research methods to calculate maximum height using kinematic equations
  • Explore practical applications of kinematics in real-world scenarios
Students in physics courses, educators teaching kinematics, and anyone interested in understanding the principles of motion and acceleration.
daodude1987
[SOLVED] Help with Constant Acceleration Lab
Hey guys, thanks for reading my post. I'm really confused about a lab that was assigned by my teacher. I will try to explain the whole lab the best I can.
Lab: The Balls Lab
Purpose of the Lab: To determine the initial velocity (Vo) and maximum height (dy) of a thrown (and hit) ball
Procedure/Materials:
Materials: tennis ball, tennis racket, stop watch
1. Throw a ball straight up into the air
2. Measure the time the ball is in the air and comes down
3. Due three trials
Data: (here are the 3 time results I got for the ball)
Throwing
Trial 1- 3.21 seconds
Trial 2- 3.10 seconds
Trial 3- 2.94 seconds
Average- 3.08 seconds
Hitting the ball with tennis racket
Trial 1- 1.41 seconds
Trial 2- 2.88 seconds
Trial 3- 1.87 seconds
Average- 2.05 seconds
Conclusion:
Ok here is the problem... I have no clue how to start solving for the initial velocity (Vo) for the average of the ball thrown and hit in the air. At first I thought the initial velocity of the thrown ball was 0 because that is usually the velocity of any object at rest and then going into the air. But my teacher said it wasn't because he wanted the intial velocity from when it left my hand not when it is at rest, which is 0. He also told me that I needed to use one of the equations of motion for constant acceleration such as: Vf=Vo+at, d=1\2(Vf+Vo)t, d=Vo=1/2at(squared), or 2ad=(Vf)squared-(Vo)squared and the acceleration of gravity, -10 m/s to solve for Vo. But he wasn't clear on which one. Also it seems to me that each of these equation require the value of Vo itself! I am also very confused at how to find the height of the thrown ball (dy) because y is not given as a variable in any of these equations.
If you guys can show me how I can solve for the initial velocity (Vo) and the maximum height(dy) of the of the ball thrown using any of the equations above or even your own methods, please enlighten me with you explanation. I am most grateful.
Thank you for taking the time to answer.
Hi,
Initial velocity:
You must think what is the relation between the time that the ball goes up and the total time of the movement you have measured. Then you must think what happens to the velocity of the ball when it reaches the highest spot of its orbit. With the above data and the proper equation of motion you can calculate the initial velocity.
Height of the throw:
You have calculated the initial velocity so the only thing you need is the time that the ball needed to get from your hand to its highest spot.
Sorry, I don’t give you the exact equations and values of time and velocity but if you fallow the steps I have written above I am sure that you will solve the problem by your own. You must think if you want to gain knowledge and on the other hand you will feel so great when you find the solution.
Excuse me for the sermon.
  • · Replies 25 ·
  • · Replies 41 ·
