Verifying Maclaurin Series for f(x)=ln(1+x)
The discussion revolves around finding Maclaurin series and power series representations for various functions, including f(x) = ln(1+x) and f(x) = 1/(1+9x^2). Participants are exploring the convergence of these series and the correct formulation of the series terms.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to derive Maclaurin series for specific functions and are questioning the correctness of their series representations. There are discussions about rewriting functions to facilitate series expansion and verifying the convergence of the series.
Some participants have confirmed the correctness of certain series representations, while others are seeking clarification on their approaches. There is an ongoing exchange of ideas regarding the manipulation of series and the application of geometric series concepts.
Some participants express uncertainty about their understanding of sequences and series, indicating a need for foundational support. There are also mentions of homework constraints and the iterative nature of the questions being posed.
Richter915
I'm supposed to find the following function as a Maclaurin Series. Please check if I'm correct.
f(x) = ln(1+x)
[tex]\sum \frac{\(x^n)((-1)^{n+1})}{n}[/tex]
and that sum goes from n=1 to [tex]\infty[/tex]
I also have to find the following functions as power series so please check it for me!
[tex]f(x) = \frac{1}{1+9x^2} = 9\sum \{(-1)^n}{x^{2n}\\<br /> <br /> <br /> \\f(x) = \frac{1+x^2}{1-x^2} = \sum \{(x)^2}+{x^{2n+2}}[/tex]
those should be two separate functions but I don't know how to separate them into two lines. both of these series go from n=0 to [tex]\infty[/tex]
You're saying that
[tex]\ln(1+x)=\sum_{n=0}^{+\infty} (-1)^{n}\frac{x^{n+1}}{n+1}[/tex]
which converges for [itex]|x|<1[/itex].It's okay.
Daniel.
Yes it's ok.
thank you both. Would you mind looking at the two power series questions I just posted...I'll probably be adding more questions throughout the day so if you could help me, it would be greatly appreciated. I'm very new to sequence and series so these questions are probably very "basic" but I do need help, thank you again.
Find a Power series representation for the function:
[tex]\frac{x}{4x+1}=4\sum_{n=0}^{+\infty} (-1)^{n}{x^{n+1}[/tex]
does that look about right to you guys?
U can write the second as
[tex]\frac{1+x^{2}}{1-x^{2}}=1+2\frac{1}{\frac{1}{x^{2}}-1}[/tex]
and it will be easier to write the series.
Daniel.
ah I just realized that I was missing a plus sign.
[tex]f(x) = \frac{1+x^2}{1-x^2} = \sum \{(x)^2}+{x^{2n+2}}[/tex]
I'm not too sure of ur method but is my answer correct?
On
[tex]\frac{x}{4x+1}= x \frac{1}{1 - (-4x)}[/tex]
Cyclovenom said:
On
Right that's what I did and I ended up with the series which I displayed.
[tex]f(x) = x\sum \{(-4x)^n} = 4x\sum {-1^n}{x^n}[/tex]
Should have been
[tex]\sum_{n=0}^{\infty} (-1)^{n} 2^{2n} x^{n+1}[/tex]
Starting with a geometric sum, find the sum of the series:
[tex]\sum_{n=1}^{\infty} {n}{x^{n-1}}[/tex]
so with this, I realized that the series is just the derivative of the geometric sum. Since I know that the sum of the geometric series is 1/(1-x), I just took the the derivative of that and got 2/(1-x)^2...does that sound about right? I want to make sure that part is right before I move on. Thank you.
Cyclovenom said:
Should have been
oh ok, so I can't just move the four out to the front like I did? I'm just glad that your correction makes sense to me, THANK YOU!
On
[tex]\frac{1+x^2}{1-x^2} = 1 + \frac{2x^2}{1 -x^2}[/tex]
That way is easier because
[tex]1 + 2x^2 \sum_{n=0}^{\infty} (x^2)^{n}[/tex]
Cyclovenom said:
On
I see but the way I did it was to rewrite the function as:
[tex](1+x^2) \frac {1}{1-x^2}[/tex]
and then I worked it from there.
Where you got that two from? in your derivative.
[tex]\frac{d}{dx} \sum_{n=0}^{\infty} x^{n} = \frac{d}{dx} \frac{1}{1-x}[/tex]
[tex]\frac{d}{dx} \frac{1}{1-x} = \frac{1}{(1-x)^2}[/tex]
oh I made a mistake...sorry...but does what I said look right?
Yes, what you said is true.
ok but now here's the problem...it says to use what I found to find the sum of:
[tex]\sum_{n=1}^{\infty} {n}{x^{n}}[/tex]
[tex]\sum_{n=1}^{\infty} \frac{n}{2^{n}}[/tex]
I honestly have no idea how to apply what I found to solve those series. If you could lead me in the right direction, it'd be greatly appreciated.
For the first one it's basically the same except we just use a little trick!, we rewrite it! :wink:
[tex]\sum_{n=1}^{\infty} {n}{x^{n}} = x \sum_{n=1}^{\infty} {n}{x^{n-1}}[/tex]
For the second one think of it this way
[tex]\sum_{n=1}^{\infty} \frac{n}{2^{n}} = \sum_{n=1}^{\infty} n (\frac{1}{2})^{n}}[/tex]
ohhh I see. I knew it was going to be some rewriting trick but I wasn't sure what to do. so for the first one I end up with x/(1-x)^2 and the second one, I just substitute x with 1/2 and I end up with 2. Alright, thanks a lot. Expect more questions soon!
ok so here's a new problem (though it relates to what I previously asked):
Find the sum of the following:
[tex]\sum_{n=2}^{\infty} {n}{(n-1)}{(x^{n})[/tex]
I rewrote that like this:
[tex]{x^2}\sum_{n=1}^{\infty} {n}{(n+1)}{(x^{n-1})[/tex]
I think this is the right direction but I have no clue where to go after this...please help, again!
You are on the right track!, except you don't know what do because you made a mistake
[tex]{x^2}\sum_{n=2}^{\infty} {n}{(n-1)}{(x^{n-2})[/tex]
Can someone also verify this infinite series for me?:
Evaluate the indefinite integral as an infinite series:
[tex]\int {e^{x^3}} = \int \sum \frac {x^{3n}}{n!} = C + \sum_{n=0}^{\infty} \frac {x^{3n+1}}{(n! (3n+1))}[/tex]
I posted my answer in there, does that look about right? Thanks.
[tex]{x^2}\sum_{n=1}^{\infty} {n}{(n+1)}{(x^{n-2})[/tex]
wait I don't see why it's x^(n-2)...when you change the series from n=2 to n = 1...x^n becomes x^(n+1)...so then when you extract x^2...it becomes x^(n-1)
also, if I continue the problem with my numbers...I get to a spot like this:
[tex]x^2 \sum_{n=1}^{\infty} ({n^2x^{n-1}) + ({nx^{n-1})[/tex]
and then I split that up into two series and one of the series equals x^2/(1-x)2 while the other (the one with the n^2) is still stuck as a series...hope that helps!
Yes i made a mistake, i meant to keep n=2, don't change it to n=1, because you will see something interesting when it's n=2.
ohhh ok, Let me try...thank you so much!
Yes it is correct.
AH!
is just x^2(f''(1/1-x)) hah, thank you so much!
cyclovenom...you were a great help...I am now done with my math homework and confident on the unsure questions...I am sure that you'll be helping me out again in the near future as I am quickly approaching finals time. Thanks again, take care.
Thanks! :smile:, it's always good to be of help.
  • · Replies 48 ·
