The discussion revolves around calculating the work done by air resistance on a thrown ball, specifically focusing on a scenario where a 5kg ball is thrown upwards with an initial velocity of 30 m/s and experiences air resistance. The scope includes theoretical calculations related to forces, work, and kinetic energy during the ball's ascent and descent.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant proposes calculating the total force acting against the ball during its ascent as the sum of gravitational force and air resistance.
- Another participant questions the unit of the stated air resistance, seeking clarification on what "25" refers to.
- A participant clarifies that the air resistance is 25N and suggests using this value to calculate work done during the ball's ascent and descent.
- It is mentioned that the work done by air resistance can be calculated as the force times the displacement, specifically noting that it would be 25N times twice the height reached.
- One participant introduces the idea of calculating kinetic energy when the ball returns to its original position, linking it to the height attained and the forces acting on the ball.
- Another participant points out that air resistance is not constant, implying that the simplification of using a fixed value of 25N may not accurately represent the situation.
Participants express differing views on the nature of air resistance, with some treating it as a constant force while others argue that it varies. There is no consensus on the best approach to calculate the work done by air resistance or the kinetic energy upon return.
Participants note that air resistance is not constant, which raises questions about the assumptions made in calculations. The discussion also highlights the dependence on the definitions of forces and the need for clarity in units used.
