Measuring Magnetic Field Strength with Hall Probe
  • Thread starter Thread starter medusa
    Probe
The discussion revolves around measuring magnetic field strength using a Hall probe positioned between two permanent bar magnets. The original poster is uncertain about the necessity of current flowing through the Hall probe to obtain Hall voltage readings, which are essential for measuring the magnetic field strength.
  • Participants explore whether current must flow through the Hall probe to generate Hall voltage, with some suggesting that charge carriers need to be in motion for the magnetic field to have an effect.
There is an ongoing exploration of the requirements for calibrating the Hall probe, including the need for a steady current. Some participants are questioning the calibration process and whether certain Hall probes might operate without an external power supply. The discussion reflects a lack of consensus on the specifics of current requirements.
Participants note the absence of current ratings from the manufacturer and express concerns about the effects of current on Hall voltage calibration. There is also mention of using a solenoid to calibrate the probe, which necessitates current flow.
medusa
there are two permamnent bar magnets put with a south pole facing a north pole.
there is a magnetic field in between the bar magnets.
i need to use the hall probe to measure the field strentgh.
the probe measures a hall voltage and i can convert this to magnetic field strength values using the calibration graph i have.
the problem i have is that i think current must flow through the hall probe so to excite the electrons so they can be deflected once the probe is in the field. otherwise i will not be able to get any hall voltage reading.
can someone explain to me that should there be current flowing through the hall probe? for me to get hall voltage readings or can i just place the hall probe in the field without any current flowing through the probe? and it just bieng connected to a voltmeter.
For the magnetic field to act on the charge carriers in the Hall probe, the carriers must be moving. If not, the v x B term in the Lorentz force will be zero and nothing interesting will occur. And to make the charge carriers move, you have to supply a potential difference to cause a current to flow.
Zz.
ok
to calibrate the probe i will be using a solenoid. so there must be current flowing through the solenoid to cause a magneic field and also current flowing through the probe to cause movement of the electrons.
but the current in the probe should be small and steady? as it is only required to cause movement of the electrons.
from this link you can see they are calibrating the probe but no mention of any current flowing through the probe.
http://dept.physics.upenn.edu/~uglabs/lab_manual/magnetic_field.pdf
medusa said:
ok
Humm... is it possible that there are Hall Probes that don't need to be attached to a power supply? I'm trying to think...
It is possible that all you need to do is set it to a particular current value and leave it at that for your calibration and measurement. The manufacturer may also provide the working settings.
Now, are you sure that these Hall probes do not have any batteries in them?
Zz.
ok i will try to find and see what settings the manufacturers give.
they give no current rating.
im sure without current no charge will flow.
but to calibrate it should constant current be passed through the probe?
like you could make a steady current of 1,2 or 3 amps to flow etc.
but this has an effect on the hall voltage therefore the it is not accurately calibrated.
If it already has a battery, this would answer everything.
I think others such as Chi Meson might be able to give you a better explanation here...
Zz.
someone help out
  • · Replies 0 ·
