Measuring Rotational Speed and Energy Conservation of a Disc
This discussion focuses on measuring the rotational speed of a disc using a tachometer and sensor tape. The tape should be placed on the periphery of the disc for optimal measurement, as the tachometer detects frequency directly related to angular speed. Additionally, the conversation addresses the conservation of energy, explaining that when a rotating disc stops, its kinetic energy is transformed into other forms, primarily thermal energy, similar to the energy transformation observed when a ball is tossed and caught.
  • Understanding of tachometers and their operation
  • Knowledge of kinetic energy and energy transformation
  • Familiarity with the principles of conservation of energy
  • Basic concepts of rotational motion
  • Research the operation and calibration of tachometers
  • Study the principles of energy transformation in mechanical systems
  • Explore the laws of conservation of energy in physics
  • Learn about angular velocity and its measurement techniques
Students and professionals in physics, mechanical engineering, and anyone interested in the principles of rotational motion and energy conservation.
chandran
i have a rotating disc. I have a tachometer and a sensor tape. Where should
i stick the tape to measure the rpm correctly? How tachometer works?
One more question.
a rotating disc has kinetic energy. Why we study energy of a rotating.
Now if i stop the rotating disc according to law of conservation of energy where that lost energy gone?
If you toss a ball in the air and catch it, where does the energy go? Same idea. The kinetic energy of the disk will be transformed to other forms of energy, such as thermal energy.
Most things we measure the rotational speed on, we simply put the tape somewhere on ther perifery of the part that is easy for the tachometer to pick up. Since you are measuring rotational speed it doesn't matter where you put it. The result is a frequency that is directly related to angular speed.
  • · Replies 39 ·
  • · Replies 22 ·
  • · Replies 87 ·
  • · Replies 19 ·
  • · Replies 77 ·
  • · Replies 21 ·
