A question on Cantor's second digitalization argument.
  • Context: Graduate
  • Thread starter Thread starter Organic
    Argument
The discussion revolves around Cantor's second diagonalization argument, specifically addressing the claim that the set of real numbers in the interval (0,1) is uncountably infinite. Participants explore the implications of Cantor's argument and challenge its conclusions by proposing alternative enumerations of real numbers.
  • One participant outlines Cantor's diagonal argument, asserting that it demonstrates there are more real numbers between 0 and 1 than natural numbers.
  • The same participant questions the validity of Cantor's argument by proposing a new enumeration of real numbers that they claim is not accounted for by Cantor's method.
  • Another participant suggests that applying Cantor's diagonal argument to the new enumeration will still yield a real number not present in the list, thus challenging the original claim.
  • A participant emphasizes that the enumeration of real numbers is arbitrary and insists that the "new list" and "original list" are effectively the same, arguing that Cantor's function cannot cover all possibilities.
  • Further responses indicate a misunderstanding of the implications of the diagonal argument and reiterate the need for clarity in the enumeration process.
Participants express disagreement regarding the validity of Cantor's diagonal argument and whether the proposed enumerations adequately address the argument's conclusions. No consensus is reached on the correctness of the claims made.
Participants reference specific decimal expansions and their implications, but there are unresolved assumptions regarding the completeness of the enumerations and the treatment of decimal representations of real numbers.
Organic
A question on Cantor's second diagonalization argument.
Hi,
Cantor used 2 diagonalization arguments.
On the first argument he showed that |N|=|Q|.
On the second argument he showed that |Q|<|R|.
I have some question on the second argument.
From Wikipedia, the free encyclopedia:
http://en.wikipedia.org/wiki/Cantor's_diagonal_argument
The proof by contradiction proceeds as follows:
• (1) Assume that the interval (0,1) is countably infinite.
• (2) We may then enumerate the numbers in this interval as a sequence, { r1, r2, r3, ... }
• (3) We shall now construct a real number x between 0 and 1 by considering the nth digit after the decimal point of the decimal expansion of rn. Assume, for example, that the decimal expansions of the beginning of the sequence are as follows.
r1 = 0 . 0 1 0 5 1 1 0 ...
r2 = 0 . 4 1 3 2 0 4 3 ...
r3 = 0 . 8 2 4 5 0 2 6 ...
r4 = 0 . 2 3 3 0 1 2 6 ...
r5 = 0 . 4 1 0 7 2 4 6 ...
r6 = 0 . 9 9 3 7 8 3 8 ...
r7 = 0 . 0 1 0 5 1 3 0 ...
The digits we will consider are indicated in bold. From these digits we define the digits of x as follows.
o if the nth digit of rn is 0 then the nth digit of x is 1
o if the nth digit of rn is not 0 then the nth digit of x is 0
For the example above this will result in the following decimal expansion.
x = 0 . 1 0 0 1 0 0 1 ...
The number x is clearly a real number between 0 and 1.
• (4) However, it differs in the nth decimal place from rn, so x is not in the set { r1, r2, r3, ... }.
• (5) This set is therefore not an enumeration of all the reals in the interval (0,1).
• (6) This contradicts with (2), so the assumption (1) that the interval (0,1) is countably infinite must be false.
Note: Strictly speaking, this argument only shows that the number of decimal expansions of real numbers between 0 and 1 is not countably infinite. But since there are expansions such as 0.01999... and 0.02000... that represent the same real number, this does not immediately imply that the corresponding set of real numbers is also not countably infinite. This can be remedied by disallowing the decimal expansions that end with an infinite series of 9's. In that case it can be shown that for every real number there is a unique corresponding decimal expansion. It is easy to see that the proof then still works because the number x contains only 1's and 0's in its decimal expansion.
My question is:
The first assumption was that we have a bijection between |N| and |R| iff R list is complete.
Then Cantor showed that there is a way to construct a real number x between 0 and 1, that cannot be put in 1-1 correspondence with any natural number.
Therefore, there are more real numbers between 0 and 1 then all natural numbers.
Now I construct the list in another way.
r7' = 0 . 0 1 0 5 1 3 8 ...
r6' = 0 . 9 9 3 7 8 0 8 ...
r5' = 0 . 4 1 0 7 0 4 6 ...
r4' = 0 . 2 3 3 5 1 2 6 ... New list
r3' = 0 . 8 2 0 5 0 2 6 ...
r2' = 0 . 4 0 3 2 0 4 3 ...
r1' = 0 . 1 0 0 1 0 0 1 ...(= Cantor's switching function resultes)
r4 = 0 . 2 3 3 0 1 2 6 ... Original list
By constructing the above list I show that there are infinitely countably many r' numbers that are not covered by Cantor's switching function.
Therefore Cantor's digitalization's second argument doesn't hold.
Please someone show my mistake.
Thank you.
Organic
Let's write down an enumeration of your list:
Code:
r1  = 0.0105110...
r1' = 0.1001001...
r2  = 0.4132043...
r2' = 0.4032043...
r3  = 0.8245026...
r3' = 0.8205026...
Then, just like any other enumeration, you apply Cantor's diagonal argument and you can generate a number that cannot appear in the list. In this case, 0.110010...
It doesn't help to post the same question twice.
Hi HallsofIvy,
By complete I mean that there are no numbers left out not in R and not in N (means bijection between N and R).
The R list is arbitrary and it is one and only one list.
"New list" and "Original list" are the same one list.
All what I showed is that we can construct it in such a way that Cantor's function can never reach all of it.
Here it is again:
r4' = 0 . 2 3 3 5 1 2 6 ... "New list"
r1' = 0 . 1 0 0 1 0 0 1 ...(= Cantor's function resultes)
r4 = 0 . 2 3 3 0 1 2 6 ... "Original list"
r1 = 0.0105110...
r1' = 0.1001001...
r2 = 0.4132043...
r2' = 0.4032043...
r3 = 0.8245026...
r3' = 0.8205026...
Then I use r'', r''' ,r'''' ,... on top of your list.
Organic
  • · Replies 21 ·
  • · Replies 43 ·
  • · Replies 55 ·
11K
  • · Replies 18 ·
  • · Replies 62 ·
11K
