Question on electrostatic pressure
The discussion focuses on calculating the electrostatic pressure between the northern and southern hemispheres of a charged metal sphere, as outlined in Griffiths' Electrodynamics, specifically question 2.39. The total charge Q is uniformly distributed across the sphere's surface, resulting in each hemisphere carrying a charge of Q/2. Using Coulomb's law, the force of repulsion between the hemispheres is derived as F = (kQ^2)/(4R^2), where R is the radius of the sphere and k is Coulomb's constant. This formula provides a definitive answer to the problem posed.
  • Understanding of electrostatic pressure in conductors
  • Familiarity with Coulomb's law
  • Knowledge of electric fields in electrostatic equilibrium
  • Basic concepts of charge distribution on conductors
  • Review Griffiths' Electrodynamics, section 2.5 for deeper insights on electrostatic pressure
  • Study Coulomb's law and its applications in electrostatics
  • Explore the concept of electric fields in conductors at electrostatic equilibrium
  • Investigate charge distribution principles in spherical conductors
Students and professionals in physics, particularly those studying electrodynamics, as well as educators seeking to clarify concepts related to electrostatic forces and charge distribution in conductors.
brianparks
I am currently working through section 2.5 of Griffiths' electrodynamics, specifically the part which deals with electrostatic pressure in conductors. I encountered the following question (question 2.39, or 2.38 in earlier versions):
A metal sphere of radius R carries a total charge Q. What is the force of repulsion between the "northern" hemisphere and the "southern" hemisphere?
I have an answer to the question, but I am not sure if it is right. Would anyone be willing to work through the problem, so that I can test my understanding of the subject matter?
Any help is greatly appreciated.
--Brian
Post your solution and we'll check it out.
Sure, I would be glad to help you work through this problem. First, let's review the concept of electrostatic pressure in conductors. In a conductor, the charges are free to move and redistribute themselves until they reach a state of electrostatic equilibrium. This means that the electric field inside the conductor is zero and the charges are distributed uniformly on the surface.
Now, let's apply this concept to the problem at hand. We have a metal sphere of radius R carrying a total charge Q. The charges will redistribute themselves on the surface of the sphere until they reach a state of electrostatic equilibrium. The electric field inside the conductor will be zero, and the charges will be distributed uniformly on the surface.
Now, let's divide the sphere into two halves - the northern hemisphere and the southern hemisphere. Each half will have a charge of Q/2, since the total charge Q is distributed uniformly on the surface of the sphere.
According to Coulomb's law, the force of repulsion between two charges Q1 and Q2 separated by a distance r is given by:
F = (kQ1Q2)/r^2
In this case, Q1 = Q2 = Q/2, and r is the distance between the centers of the two hemispheres. Since the distance between the centers is equal to the radius R, we can rewrite the equation as:
F = (kQ^2)/(4R^2)
Therefore, the force of repulsion between the two hemispheres is given by:
F = (kQ^2)/(4R^2)
I hope this helps you understand the problem better. Let me know if you have any further questions or if you would like me to go through the problem in more detail. Keep up the good work!
  • · Replies 22 ·
  • · Replies 23 ·
11K
