Calculating Minimum Breaking Tension for Vine Rope Swing
The problem involves calculating the minimum breaking tension of a vine rope used by a person swinging across a hole, with the rope making a maximum angle of 40 degrees to the vertical. The individual is treated as an 85 kg point mass.
  • Participants discuss the forces acting on the rope during the swing, questioning whether the problem relates to torque or centripetal force. Some suggest using equations related to centripetal force and energy conservation, while others express uncertainty about the necessity of the rope's length for calculations.
Several participants have offered insights into the forces involved and potential equations to use, particularly focusing on centripetal force. There is an ongoing exploration of the problem, with different interpretations and approaches being discussed.
Participants note the importance of the rope's length in determining the height and forces involved, indicating that some information may be missing for a complete analysis.
b_phys28
A guy wishes to swing across a hole, using a vine rope. In order to reach the other side he must swing so that the rope makes a maximum angle of 40 degres to the vertical. Regarding the guy as an 85 kg point mass, what is the minimum breaking tension of the rope if the rope is not to break?
When the man is swinging, what are the forces on the rope? Where are they maximum? What are the forces on the rope at that point?
AM
Crazy, is this a torque or like.. centripetal force question?.. or.. haha sorry I'm trying to learn too.
This is a centripetal force question. You can use the following equations:
F = ma
a = v^2/r
KE is at a max at the bottom of the swing, PE is at a max at the starting point. so mgh = (1/2)mv^2.
You can calculate the height, but you need the length of the rope to figure that out.
I can't really think of a way to do this without the length of rope. If you have it, just use trig, get the h, plug it in.
F = ma
a = v^2/r
I don't think you need the length of the rope. The PE is converted to KE at the bottom:
[tex]mgRsin(40) = PE = \frac{1}{2}mv^2[/tex]
[tex]mv^2/R = F_c = 2mgsin(40)[/tex]
So the maximum force on the rope (at the bottom) is:
[tex]F_{max} = mg + F_c = mg + 2mgsin(40) = mg(1 + 2sin(40))[/tex]
[tex]F_{max} = 85*9.8(1 + 2(.6428)) = 1903 N[/tex]
AM
  • · Replies 38 ·
  • · Replies 20 ·
