The discussion revolves around the internal forces in coaxial circular bars made of different materials (steel and aluminum) when subjected to an external force of 30 kN. Participants explore the implications of this loading scenario, considering both the compressive loads and the material properties of the bars.
- Technical explanation
- Debate/contested
- One participant suggests that the internal forces in both bars will be 30 kN if the load is applied to both parts.
- Another participant questions the clarity of the load application, indicating that if the load is applied only to the inner bar, the analysis may differ.
- A later reply introduces the concept of calculating compressive deformation using the formula Δ = PL/AE, suggesting that the internal stress and contact pressure between the bars may need to be considered.
Participants do not reach a consensus on whether the internal forces in both bars are indeed 30 kN, as there is uncertainty about how the load is applied and its effects on the bars.
The discussion lacks clarity on the specific loading conditions and the assumptions regarding material properties and interactions between the bars.
