Basis of degree of freedom for monoatomic and diatomic mixture
The discussion revolves around calculating the ratio of specific heats (Cp/Cv) for a mixture of helium and oxygen gases. Participants are exploring the implications of the degrees of freedom for monoatomic and diatomic gases in this context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the classification of helium as a diatomic gas and discussing its properties as a noble gas. There are inquiries about how to derive a formula for Cp/Cv based on degrees of freedom, as well as discussions about the number of moles and atoms in the mixture.
Some participants have provided equations and factors related to the specific heats of the gases involved, while others are seeking further clarification and proof of the equations presented. There is an ongoing exploration of the concepts without a clear consensus on the approach to take.
Participants have noted the challenge of deriving an effective lambda factor for the mixture and the absence of certain equations in standard textbooks, indicating a potential gap in available resources for this problem.
nomorevishnu
hi guys
16 grams of helium gas is mixed with 16 grams of oxygen...
what will be the ratio Cp/Cv of the mixture...
how to calculate it?? i thought on the basis of degree of freedom for monoatomic and diatomic mixture...but that can take me to the answer only by approximation...how do we arrive in a a formula that could get me answer...
Aren't they both diatomic?
AM
how?
y do u say that these two are diatomic?
He...its completely satisfied without bonding
He is a noble gas...so y do u say it is diatomic...
moreover someone help me solve the problem yaar...
Monatomic Gases:
Helium, Neon, Argon, Krypton, Xenon, Radon
Single atom, or monatomic, gases have the smallest Specific Heat CV.
Diatomic Gases:
Oxygen, Nitrogen, Hydrogen
Of course you are right. I was seeing He and thinking H.
What is the ratio of the number of He atoms to O2 molecules?
AM
hi
y isn't anyone helping me get the answer?
please if someone can explain the problem to me...it would do a world of good to me...
please please please...the question again...
nomorevishnu Let helium be the gas 1 and oxygen be the gas 2 .
No. Of moles of Helium: 4 = n1
" " " " oxygen: 0.5 =n2
Lamda factor for a mixture is given by:
L= n1( Cp1) + n2 (Cp2) / n1(Cv1) + n2 (Cv2)
Where Cp1/Cv1=5/3 ( for monoatomic helium)
Cp2/Cv2=7/3 for diatomic oxygen
Answer you get is: 1.62
nomorevishnu said:
hi
Have you worked out the proportion of numbers of atoms of He to number of molecules of O2?
AM
well...i knew that equation...and the answer
but to find the effective lambda...how do we get to such an equation...any proof...its not given in Resnick and Halliday
You have to go to basic principles:
[tex]dU = (Cp - Cv)nT = nRT[/tex] so:
[tex]C_p/C_v = \gamma = (C_v + R)/C_v = (1 + R/C_v)[/tex]
So for the mixed gas:
[tex](C_{peff} - C_{veff})n_{total}dT = n_{total}RdT[/tex]
[tex]C_{peff} = (R + C_{veff})[/tex]
(1)[tex]C_{peff}/C_{veff} = \gamma_{eff} = (R/C_{veff} + 1)[/tex]
Now:
[tex]Vdp = (C_{vHe}n_{He} + C_{vO_2}n_{O_2})dT = C_{veff}n_{total}dT[/tex]
(2) [tex]C_{veff} = (C_{vHe}n_{He} + C_{vO_2}n_{O_2})/n_{total}[/tex]
Substitute from (2) into (1).
I get 1.64
AM
12K
18K
43K
9K
