| New Reply |
"Iron core energy change" and "transformers vs. ohms law" |
Share Thread |
| May8-05, 03:11 PM | #1 |
Ooh yes, I do have two question. So enjoy the meal all physics lovers!
1. If the field is increased putting an iron core inside the circuit, then what about energy conservation? (I don't know much about H-fields.) 2. Alright, now I do understand (really!) why a transformer will change both current and voltage and why power is conserved. But what about Ohms law then? According to Ohms law I will depend on U and vice versa. This applies to A.C. as well, right. So that does not make sense to me. Happy days to everyone! /Order |
| May8-05, 06:25 PM | #2 |
Recognitions:
2. The inductive reactance limits current. If you increase current draw on the secondary, the inductive reactance in the primary decreases and the current increases. Ohm's law applies but you have to use the formula for impedance: [tex]Z = \sqrt{R^2 + (X_L - X_C)^2}[/tex] AM |
| May9-05, 05:04 AM | #3 |
1. Ok, The field change will induce a current according to Lenz law if the core is there to start with. (So it is kind of like charging the magnet, although not quite.) Or it would require work to put it there if you try to plug it in while current is working. That's a good explanation for now. 2. Yes, I also believe that the inductive reactance (or whatever ) will reduce the current. Dut how could normal resistance do the same thing? The field change will induce a voltage, depending on the number of turns according to the law of inductance. And the field will be cancelled by the current, induced according to Lenz law and also depending on the number of turns. This must be so! For if the right amount of current was not induced, the magnetic field would not cancel. So the current won't care about the resistance, it seems.So that's my conceptual problem. Now over to the easy calculational problem: I thought you should calculate voltage and current using these laws: [tex]V_2 = V_1 \cdot \frac{N_2}{N_1}[/tex] [tex]I_2 = I_1 \cdot \frac{N_1}{N_2}[/tex] However, you seem to suggest that I should use the law of power conservation [tex](I_1 \cdot V_1 = I_2 \cdot V_2)[/tex] together with Ohms law [tex](U = Z \cdot I)[/tex]. Which one is correct? The problem is that I have a conceptual understanding of the former method, but not of the latter. So if the latter method is correct, my world will fall apart.
| May9-05, 09:18 AM | #4 |
Recognitions:
"Iron core energy change" and "transformers vs. ohms law"AM |
| May9-05, 02:52 PM | #5 |
But I still don't understand why, in the case of an ideal transformer, the field isn't neutralized both in the secondary and the primary. Why is all the neutralization located at the secondary? Why doesn't Lenz's law work at the primary? Magnetic flux should pass here as well. |
| May9-05, 03:06 PM | #6 |
Recognitions:
AM |
| May14-05, 03:06 PM | #7 |
I still have some questions, but I have to check the equations first. This is a really good forum! You get the bits and pieces you need to solve the problem. I have a much better understanding of transformers by now. Thanks for your help Andrew! (I had a little help running the Java transfromer at http://www.ngsir.netfirms.com/englis...ransformer.htm by the way.) |
| May14-05, 05:29 PM | #8 |
Recognitions:
What happens physically is that the energy is put into increasing the magnetic field on half the cycle and the energy is regained when the field decreases. However, since the core is iron (a conductor) little induced eddy currents occur in the core and this causes heat losses (look up hysteresis). This is minimized by laminating the core so there is a stack of insulated iron sheets instead of a block of iron. There are still losses though. So there is still a heat loss even with no resistance in the primary. BTW, your persistence is commendable. AM |
| May26-05, 02:38 PM | #9 |
Interesting things said about hysteresis. Why didn’t anyone tell me before? I told Andrew I would look at some equations and then come back. The equation I’m concerned about is the differential equation for the RL-circuit: [itex]u = R \cdot i + L \cdot \frac{di}{dt}[/itex] This equation says that the inductor will hinder the effective voltage [itex]R \cdot i[/itex] to build up. But to me this equation doesn’t make sense, although I would agree it is correct. Let me explain this in the case of a positive DC voltage.First of all, from the physical (not mathematical!) viewpoint, why wouldn’t the term [itex]L \cdot \frac{di}{dt}[/itex] exceed the voltage? Because then we would have a negative voltage over the inductor causing the current to flow backwards (or at least decrease). But this is an absurdity since the current has to always increase to keep the term positive. I have no complaints this far. The second question is: why would the current increase at all. If you solve the equation you will (of course) find an increasing current. The funny thing is that, according to me, the equation doesn’t give a physical reason why the current would increase. Looking at a certain time the effective voltage is [itex]R \cdot i[/itex], which is enough to drive a current [itex]i[/itex]. It is not enough to drive a current [itex]i+di[/itex]! Now my idea is that in real life the term [itex]L \cdot \frac{di}{dt}[/itex] would be somewhat smaller than [itex]u - R \cdot i[/itex]. Then that would allow for current to build up, since you then have a “net voltage”. This can be done if the differential equation is modified: [itex]u = R \cdot i + (1+k) L \cdot \frac{di}{dt}[/itex] where k<<1. The constant k would probably be extremely small. But at least this modified equation doesn’t contradict Newton’s second law: a particle will need a force (voltage/meter*charge) in order to accelerate. So the second equation would make sense to a physicist, but an engineer wouldn’t care.Now what is so interesting about this? I don’t know if I’m right. But I do feel that some equations in physics are very effective in hiding the conceptual aspects. They are almost impossible to understand as they stand, hiding important physics in an infinitesimal (infinitely small) corner. Is this right? Has anyone else thought about this? /Order |
| May27-05, 03:13 PM | #10 |
Recognitions:
When the DC circuit is closed, the applied voltage causes current to flow and the induced back-emf causes current to flow in the opposite direction. The rate of change of current cannot produce an induced voltage that causes more current to flow through the resistance than the applied voltage causes to flow. If you could do that you would be producing more energy than you are delivering to the circuit. AM |
| May28-05, 03:17 AM | #11 |
. I have a picture about how the fields are hindering current to flow. What I'm trying to understand right now is how to understand if the differential equation is complete or if it describes an ideal situation.My suggestion was that it wasn't complete and that you would need a damping term [itex]k \cdot \frac{di}{dt}[/itex] to make it more realistic. For suppose the electrons were extremely heavy. Then they wouldn't accelerate very easily. And the acceleration of electrons is the same thing as increasing current. Then current would need more time to build up. Now suppose the electrons are as ultra-light as they are in reality. Then they would still hinder current to build up. And the damping term would still be valid, although the constant k would be small. (Having appreciated it in my head it seems to be small.) This applies to the equation [itex]u = R \cdot i[/itex] as well. Otherwise current would build up instantaneously, revealing an infinite force. You could also need terms to take heat loss into consideration. To solve this new differential equation could be messy, or it could be just as easy. But it shouldn't be done really. The purpose of the equation is to show that there is a connection between mechanics and electricity. In the original differential equation there is no such connection. Isn't this a valid point? To understand any differential equation you would have to know what it doesn't take into account. This is often left unanswered by physicists. That is my point. /Order |
| May28-05, 10:29 AM | #12 |
Recognitions:
AM |
| May28-05, 02:41 PM | #13 |
u is the applied voltage (it is a number fixed by the power supply/battery) not some "effective voltage"; iR is the voltage drop across the resistor; and Ldi/dt is the voltage drop across the ends of the inductor. The fact that the electric field generated by the battery is a conservative field (ie : the work done by the field on a charge is path independent, or the work done over a closed loop is zero) requires that the voltage gain provided by the battery equal the total voltage drop across various elements in the circuit. This concept is contained within Kirchoff's Voltage Law. At t=0, there is no current and hence no drop across the resistor. So, the entire potential drop is across the inductor, or Ldi/dt = u. Since u > 0, di/dt > 0. This tells you that i must increase from its initial value of 0, causing a potential drop to appear across the resistor. For the equation to work (which it must, for the reason stated in the previous paragraph), as iR increases, Ldi/dt must decrease, so as the keep the sum constant. Since Ldi/dt started out equal to u and has henceforth only decreased, it can not exceed u (in theory). When an inductor is included in the circuit, there is an addition retarding force coming from the induced magnetic field whose value is proportional to the rate of change of the field/current (and hence disappears in the steady state). This slows the current growth over time scales that are much bigger than the relaxation (or scattering) time. |
| May29-05, 09:17 AM | #14 |
.(Really, I wrote about acceleration. But this was a naïve thought, as Andrew pointed out. It's a good thing you don't have to use your real name in this forum ![]() .)/Order |
| Nov6-10, 02:26 AM | #15 |
You can say that I am a complete beginner when it comes to physics. This query by Order made me curious and I did some research on the subject. I was able to find out that the best way to conserve energy is by putting an iron core inside a coil that is carrying current. By doing so we will be able to increase the strength of the magnetic field and this in turn results in energy conservation. A lot of research is going on regarding this concept.
| New Reply |
Similar discussions for: "Iron core energy change" and "transformers vs. ohms law"
| Difference between "Identical", "Equal", "Equivalent" | Calculus & Beyond Homework | 9 | ||
| "Do Androids Dream of Electric Sheep" vs "Blade Runner" | General Discussion | 0 | ||
