Why do capacitors and inductors have imaginary impedance?
The discussion centers on the concept of imaginary impedance in capacitors and inductors within AC circuits. Impedance is defined as a complex number, where the imaginary components indicate a 90-degree phase difference between voltage and current. Specifically, voltage leads current in inductors and lags in capacitors, summarized by the mnemonic "ELI the ICE man." The impedance of an inductor is mathematically represented as Z_L = jωL, where j denotes the imaginary unit, ω is the angular frequency, and L is the inductance.
  • Understanding of AC circuit theory
  • Familiarity with complex numbers and phasors
  • Knowledge of inductance and capacitance
  • Basic calculus for integration in circuit analysis
  • Study the relationship between voltage and current in AC circuits using phasors
  • Learn about the impedance of capacitors, specifically Z_C = -j/(ωC)
  • Explore the concept of resonance in RLC circuits
  • Investigate the application of complex numbers in electrical engineering
Electrical engineers, physics students, and anyone interested in understanding AC circuit behavior and the role of impedance in circuit analysis.
Hybird
Consider an AC source with series elements (resistor,inductor, capacitor). In order to determine information from the circuit it is useful to consider impedance. So here's the question, total impedance is a complex number, and that is because the impedance of the cap and inductor are imaginary numbers. I'm tryin to find out why they are imaginary.
Any help?
Any help?
In a complex number representation, sinusoidal functions are written as complex exponentials. The imaginary numbers for the impedence of capacitors and inductors indicates that the voltage and current in these devices is 90 degrees out of phase. Voltage leads the current in an inductor and lags the current in a capicitor. The catchy little phrase "ELI the ICE man" can help you remember which is which.
Well let's just talk about the impedance of an induction. The impedance is defined as followed
[tex]Z_L \equiv \frac {\mathbf{V}_L}{\mathbf{I}_L}[/tex]
where [itex]V_L[/itex] and [itex]I_L[/itex] are phasors. Consider [itex]v_s(t) = A \cos (\omega t)[/itex], then [itex]\mathbf{V}_L = A \angle 0[/itex]. The current through an inductor is given by
[tex]i_L(t) = \frac {1}{L} \int_{t_0}^t v_L ~dt + I_0[/tex]
If you work that integral out will you get [itex]i_L(t) = \frac {A}{\omega L} \sin(\omega t) = \frac {A}{\omega L} \cos(\omega t - \frac {\pi}{2})[/itex]. So [itex]I_L = \frac {A}{\omega L} \angle -\frac {\pi}{2}[/itex]
Then
[tex]Z_L \equiv \frac {\mathbf{V}_L}{\mathbf{I}_L} = \frac {A \angle 0}{\frac {A}{\omega L} \angle - \frac {\pi}{2}} = \omega L \angle \frac {\pi}{2} = j \omega L[/tex]
The complex number [itex]j[/itex] appears in the impedance of an inductor when converting from polar form to rectangular form. Hope that answered your question.
  • · Replies 21 ·
  • · Replies 16 ·
10K
