Vector velocity homework question
The discussion revolves around a physics problem involving vector velocity, specifically calculating the velocity of a skater moving from one position vector to another at a constant speed. The subject area includes vector mathematics and kinematics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to determine the direction of the velocity vector by finding the difference between the final and initial position vectors. There are attempts to clarify the correct method for calculating the resultant vector and its unit vector, as well as how to apply the magnitude of the velocity.
Some participants have offered guidance on the correct approach to finding the direction of the velocity vector, emphasizing the importance of using the difference between position vectors. There is recognition of the need to establish a unit vector and apply the given speed, although no consensus has been reached on the final method.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. The discussion reflects varying interpretations of vector operations and the setup of the problem.
Gughanath
On an occasion, John has position vector 40j metres. He wished to skate in a straightline to the point with position vector 30i metres. Given that his speed is constant at 5ms^-1, find his velocity.
Someone help me on this one please! :confused:
You have a magnitude (5 meters per second).
The starting coordinates (0,40) and the ending coordinates (30,0) supply the direction. Relative to your origin (0,0) your two position vectors are 0i + 40j and 30i + 0j
Since you're using ijk coordinates, your best bet is to add your two position vectors together. Then you have a scalar problem: x(30i + 40j) = v
To find x, you have to divide the magnitude of the velocity vector by the magnitude of the resultant position vector. Plug the coordinates of your position vector into the Pythagorean Theorem.
Once you determine x, do the scalar mutliplication (multiply each of the resultant position vector coordinates by x).
Oh!...Thanx
Gughanath said:
Oh!...Thanx
You need the difference between the final and initial position vectors, not their sum, to get the direction of your velocity vector
[tex] \overrightarrow {\Delta r} = \overrightarrow{r}_{final} - \overrightarrow {r}_{initial} = 30\widehat{i} - 40\widehat{j}[/tex]
Since you know the magnitude of your velocity vector, you need to find the unit vector in the direction of [tex]\overrightarrow {\Delta r}[/tex]. You can do that by dividing the vector [tex]\overrightarrow {\Delta r}[/tex] by its length. Then multiply that unit vector by the magnitude of the velocity you have.
Oops. OlderDan's right. It's final position minus start position.
It's -30i +40j , not +30i.
  • · Replies 18 ·
