Thread Closed
Initial Velocity of a falling object
Share Thread Thread Tools
May9-05, 06:45 PM   #1
Exclamation
Hello everyone
I know that [tex] \sqrt { \frac {2d} {g} } [/tex] but what about including initial velocity?
Thanks in advanced
"Im the master of time" -- Eiffel 65
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May9-05, 07:01 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by eNathan
that _what_ is [tex] \sqrt { \frac {2d} {g} } [/tex]?
It's [tex]t= \sqrt { \frac {2d} {g} } [/tex].
Where did that equation come from?
May9-05, 07:03 PM   #3
Mentor
[tex]y = y_0 + v_0 t - \frac {g t^2}{2}[/tex]
This is the kinematic equation describing a falling body (ignoring air resistance). Here "up" is positive and "down" is negative; "y" is the position after t seconds; [itex]y_0[/itex] is the initial height; [itex]v_0[/itex] is the initial speed.
May10-05, 09:20 AM   #4
robphy, we all know what I meant.
Thanks Doc_Al!
May19-10, 07:18 AM   #5
Quote by Doc Al View Post
I am still not clear why the time of the initial velocity (going up) is equal to the t in 1/2gt^2. Will someone enlighten me?
May19-10, 07:30 AM   #6
Mentor
Quote by RENATO View Post
I'm unclear what you are asking. What do you mean by "time of the initial velocity"? Please rephrase your question. What problem are you trying to solve?
May19-10, 07:43 AM   #7
If a person is standing on top of the cliff, throws the ball upwards at 15 ft/sec from an initial height of 50 ft. How high is the rock after 2 seconds. Also, what is the total time when it hits the ground at 50 ft below.
I know I can solve the problem by following the formula y=1/2 at^2 +Vot +yo, yo being the initial height. What is not clear to me is why is t (time) the same throughout the equation.
May19-10, 07:54 AM   #8
Mentor
The time (t) in that equation is a parameter that continually changes. t = 0 is the moment when the ball is first thrown. That equation tells you how the position of the ball changes as a function of time, where time is measured from the moment the ball was thrown.
May19-10, 08:00 AM   #9
Thank you so much. I do understand now.
May19-10, 08:09 AM   #10
That equation still will not give you the correct answer. That is for if the initial velocity is orthaginol to gravity. You are not accounting for the distance traveled in the positive y direction.
You need velocity to start out positive at a decreasing rate, and end up negative at an increasing rate. Either work it piecewise find a path function.
May19-10, 08:16 AM   #11
Mentor
Quote by cstoos View Post
You have it backwards. That equation only deals with vertical motion (in the y direction). The v0 in that equation is just the y-component of the initial velocity.
Jun17-10, 02:08 PM   #12
[QUOTE=RENATO;2723823]If a person is standing on top of the cliff, throws the ball upwards at 15 ft/sec from an initial height of 50 ft. How high is the rock after 2 seconds. Also, what is the total time when it hits the ground at 50 ft below.
I know the formula y=1/2 at^2 +Vot +yo, yo being the initial height. What is not clear to me is why is t (time) the same throughout the equation.
Will someone solve for the height after 2 seconds and the total time so I would know if my answers are correct.
Jun17-10, 02:18 PM   #13
Mentor
Why don't you show what you did and we'll take a look at your work? (As I thought was explained before, time is just a parameter. That formula gives the position as a function of time.)
In one case, the time is given and you'll calculate the position. In the other case you know the final position and you have to solve for the time. You use the same equation for both parts.
Jun17-10, 02:28 PM   #14
I can only solve for the height after 2 seconds which is 15.6 ft, but I do not know how to solve for the total time.
Jun17-10, 02:42 PM   #15
Is the following correct:
-50 = Vot -32.2/2(t^2)
-50 = 15t -16.1t^2
t = 2.28
Jun17-10, 02:50 PM   #16
or is it 3 seconds, now I am guessing.
Jun17-10, 03:11 PM   #17
Another way of solving, which I am not sure is:
d =Vot + (0.5)at^2
50= (-15)t + 16.1 t^2
t= 2.28 seconds
Thread Closed
Thread Tools
Similar Threads for: Initial Velocity of a falling object
Thread Forum Replies
Initial speed of a thrown/falling stone Introductory Physics Homework 8
Calculating initial velocity of a bouncing object Classical Physics 4
Free Falling Object's Initial Height Introductory Physics Homework 11
Given an initial position and velocity of a receiver, find the velocity of a ball Introductory Physics Homework 7
Calculating initial velocity for object.... Introductory Physics Homework 2
