Can a House Survive a 747 Engine Falling From 35,000 Feet?
  • Context: Undergrad
  • Thread starter Thread starter nightshadz
    Movie Physics
The discussion centers around the hypothetical scenario of a 747 jet engine falling from 35,000 feet onto a suburban house, exploring the potential damage to the structure and the physics involved in such an event. Participants examine various factors including the weight of the engine, its terminal velocity, and the structural integrity of the house.
  • Some participants suggest that the engine's density and size could lead it to penetrate the house, causing localized damage while leaving much of the structure intact.
  • Others argue that the engine's horizontal velocity upon impact, potentially exceeding 100 mph, would result in significant destruction.
  • There is uncertainty about the engine's weight, with estimates ranging from 2-3 tons to as high as 12-13 tons based on different assumptions and references.
  • Participants discuss the concept of terminal velocity and its relevance to the scenario, with some expressing confusion about how to calculate it.
  • One participant mentions that reports of cars crashing into houses show that damage can be confined to a small area, drawing parallels to the engine scenario.
  • Several participants provide calculations regarding potential energy and kinetic energy, with varying assumptions about air resistance and impact velocity.
  • There are references to the design of jet engines, noting that they are not as dense as one might expect due to their construction.
Participants do not reach a consensus on the extent of damage a falling engine would cause, with multiple competing views on the engine's weight, impact dynamics, and structural effects on the house remaining unresolved.
Participants express uncertainty regarding the calculations of terminal velocity and the assumptions about the engine's weight and aerodynamics. The discussion includes various estimates and references that may not be definitive.
nightshadz
After watching Donnie Darko I was curious about a scene where a 747 Jet Engine (just the engine) falls out of the sky and onto the corner of a rather large suburban house. In the movie the house was intact (minus some damage to the side it landed on). Assuming something like this happened in reality, would it be possible for the house to remain somewhat intact if the 747 Jet Engine fell from 35,000 feet onto the corner of the house?
I was having an argument about this with a friend of mine and figured a physics forum would be the best possible place to find an answer. :biggrin:
There are an awful lot of unknowns.
1) What's the terminal velocity of an engine?
2) What's the weight of an engine?
3) What's the shear strength of 4x4 wooden beams?
It seems reasonable to me that a pretty dense, relatively small object like an engine would plunge right through a house, breaking the frame members it directly strikes, but leaving most of the rest of the structure intact. It's much more like a bullet than a bomb.
- Warren
I tried looking up the weight of a 747 Jet Engine but I couldn't find it. I would assume it to be at least 2-3 tons.
I have no idea what the terminal velocity would be. My physics stopped at high school 10 yrs ago :smile:
Thanks for any help!
Now if someone could dig up the approximate size of the engine we could have a classic post starting with "assume a spherical engine" in the makings.
I guess someone must have calculated the air resistances for cylinderical or water droplet like objects so that part is solvable.
nightshadz: terminal velocity is the maximum velocity a falling object can attain before gravity and air's resistance cancel each other out leaving the object falling at a constant velocity.
I highly doubt the thing would be intact. The engine must have hit the house with a horizontal velocity of at least a hundred miles per hour or so meaning it would plow through the house along with the damage inflited simply because of its energy from falling a few thousand feet.
I know what Terminal Velocity means, i just don't know how to derive it and how to apply it to this problem. Sure I could look it up and plug in some numbers, but those numbers won't have any meaning to me regarding this question. :smile:
Also, assuming it did fall from 35,000 feet, wouldn't it eventually end up dropping completely vertical by the time it impacts?
Yes, I was assuming wind resistance would kill its horizontal velocity by the time it hit the ground. That may or may not be a good assumption, but I don't think a tumbling engine is all that aerodynamic.
- Warren
oh sorry, I misread your post.
There are a lot of reports of cars crashing into houses at very high speeds, and the over all damage is confined to a small area. A lot times the car doesn't even make it into the house. I assume a jet engine' weight is similar (probabally less) than a car. To me it seems highly probable that the majority of the house would remain intact. As was mentoned its a projectile not a bomb.
The 747 uses Pratt & Whitney JT9D high-bypass turbofans. They are 97" in diameter, 132" long, and produce from 46,300—56,000 pounds of thrust depending upon the specific model. I can't find a weight figure for them anywhere, but all aviation engines use as light a material as they can get away with, and the biggest part of that engine diameter is just the bypass fan at the front. I'm not sure that one would even reach a ton in weight.
My god it is just a movie. Its like armaggeddon and the gravity of the asteroid. Just get over it and enjoy the moive.
But I enjoy this more than movies. That's why I'm here instead of watching one. :-p
Don't forget that the engine in question took a trip through a time vortex (or equivalent movie-science buzzword), which could have changed its velocity in an arbitrary way to suit any required plot line...
I know. That's why I created this thread. To find out what would actually happen assuming a 747 Jet Engine fell from 35,000 feet (without the help of a wormhole). :wink:
I don't know the weight of those engines, but I know the engines some B-57 bombers (jet engines) use produce about 1/10th that thrust and weigh about 1.25 tons. Assuming a direct relationship, the engine in question would weigh around 12-13 tons. Not exact, but it's a starting place.
Well, I think its 4 tons. I got this number from a PDF I downloaded which I've linked to. It makes a non-detailed reference to this weight, although coincidentally the aim of the PDF is very, very much related to the question.
PDF: http://www.engineering-eye.com/AUTODYN/customer/paper/pdf/ESHP_1.pdf
assuming the engine fell from h meters and has a mass of m
it would have protentional energy of
[tex]u=mgh[/tex]
ill take a guess here and say that because the engine isn't all that big it doesn't have that much air resistance so suppose it falls in a vacuum
so upon impact it has kinetic energy of
[tex]e= \frac{mv^2}{2}[/tex]
[tex]2mgh=mv^2[/tex]
[tex]v= \sqrt{2gh}[/tex]
suppose it doesn't lose due to air resistance more than 80% of its vacuum falling speed
[tex]v= \frac{4 \sqrt{2gh}}{5}[/tex]
if it falls from 35,000 feet (10,668 meters) it would have a velocity of at least
v=366 m/sec (1318 km/h)
im pretty sure it would simply act like a bullet penetrate through the roof and leave a big crater on the floor :biggrin:
747 engine: RollsRoyce RB211 : http://home.swipnet.se/~w-65189/transport_aircraft/b747/boeing_747_series.htm
There are some widely conflicting specs for it, but this one appears to give numbers that include the cowling, not just the naked engine: http://www.easa.eu.int/doc/Events/Rolls_Royce.pdf
Weight: 13,900 lbs :
Rolls Royce size: ~208"x168"
Airliner crusing speed: ~500mph
Airliner cruising altitude: 35,000-40,000ft
Edit: deleted obsolete calcs
OK, I found another formula that got me a better result for the test case (Got me within an order of magnitude for human v(t).)
First, the real surprise is just how dense an aircraft engine isn't. The mass divided by the volume is slightly less than 0.1g/cm^3! If it were sealed in a plastic bag, it would float 9/10ths out of the water!
OK, takes sense once you think about it, by design, an engine is a mostly air-filled cavity. Boats float with most of their volume out of the water too.
As far as air resistance, one can assume the engine stops working fairly quickly as it falls, so the blades act more as a wall than a passage for airflow. Thus, the engine acts as a solid sphere as far as air resistance goes.
The formula for terminal velocity is:
[tex]v_t = \frac{.222 \cdot g \cdot (d_s-d_a) \cdot r^2}{n}[/tex]
(reference)
where
g = gravity 9.8m/s
[tex]d_s[/tex]= density of object (.099g/cm^3)
[tex]d_a[/tex]= density of air (.001239g/cm^3)
r is the radius of the "sphere" (210cm)
n is the "dynamic viscosity of air near the Earth's surface" (0.00018 g/cm/s)
I get a number of approximately 50m/s, which is a mere 100 mph.
That provides momentum of 315,000 kg-m/s. That is twice the momentum of a 3000kg car moving at 100mph.
One other factor: the engine is moving downward, not laterally. A house can deform laterally, but it will not deform vertically since the ground is immovable. This would lessen the amount of damage it would do (since much of the impact would be transferred to the ground)
Conclusion:
I would conclude that a jet engine falling on a house would do amount of damage that is within 1x and 2x the amount that a car hitting it at 100mph would do.
Thus, the effect in the movie is pretty much bang on on the plausibility scale.
P.S. My wife loves that movie.
If I recall correctly, in the movie the engine falls through the roof and comes to rest in a second-storey bedroom... I'm thinking that the ground storey must have a pretty tough ceiling!
My assumption has wind resistance not playing a large enough factor to bring the engine to any reasonable speeds (under 100mph). It probably started at 500-600mph and I assume the engine is actually, if it stays in the correct orientation, a rather aerodynamic structure. If it just fell off, it seems like it would stay in its correct orientation for a good deal of time. If it was forced off by like an explosion though, it probably started tumbling immediately... I wonder if boeing has done an experiment for this lol.
11K
9K
