Is There a Cube Inscribed in a Sphere with All Black Vertices?
  • Context: Graduate
  • Thread starter Thread starter msmith12
    Cube Inscribed Sphere
The discussion centers on the mathematical problem of determining whether a cube can be inscribed in a sphere with 10% of its surface area painted white and the remaining 90% black. The key argument presented is that if the diameter of the circle formed by the projection of the white-painted segment is less than the side length of the cube, then it is possible to inscribe the cube such that all its vertices are black. The method involves calculating the arc length corresponding to the white-painted area and deriving the angle at the center of the sphere to find the diameter of the projected circle.
  • Understanding of geometric shapes, specifically cubes and spheres.
  • Knowledge of surface area calculations and projections.
  • Familiarity with arc length and central angles in circles.
  • Basic principles of color theory in mathematical contexts.
  • Study the properties of inscribed shapes in spheres.
  • Learn about geometric projections and their applications.
  • Explore the concept of arc length and its calculations in circles.
  • Investigate mathematical proofs related to color distributions on surfaces.
Mathematicians, geometry enthusiasts, and students studying advanced geometry or mathematical proofs involving inscribed shapes and color theory.
msmith12
Can anyone help me with this problem?
Suppose a sphere is colored in two colors: 10% of the surface is white, and the remaining part is black. Prove that there is a cube inscribed in the sphere such that all vertices are black
thanks
~matt
Mathematics news on Phys.org
This may have many solutions, provided the white paint is continuous, but I came up with this rather crude method. What you have to prove is that the diameter of the circle formed by the projection of white painted segment is lesser than the side of the cube.
If the surface area painted in white is 10% then length of the arc with the same radius that of the circle is also 10% of the circle circumference. Now you can get the angle intended by the arc at center. Now calculate the diameter of the projected circle.
  • · Replies 33 ·
  • · Replies 51 ·
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 17 ·
