Calculating Work Done by an Ideal Gas in a Three-Step Transformation
The discussion revolves around calculating the work done by a monatomic ideal gas during a three-step transformation involving changes in pressure, volume, and temperature. The context includes the ideal gas law and thermodynamic processes.
  • The original poster attempts to determine the work done during the second step of the transformation, expressing a need to find pressure as a function of volume. Some participants suggest using the ideal gas law as a potential approach.
The discussion includes attempts to clarify the relationship between pressure and volume, with some participants providing brief responses. However, there is no explicit consensus or detailed exploration of the problem's complexities.
The original poster mentions the need to express the work done in specific terms, indicating a focus on the mathematical formulation within the constraints of the problem.
~angel~
A monatomic ideal gas has pressure p_1 and temperature T_1. It is contained in a cylinder of volume V_1 with a movable piston, so that it can do work on the outside world.
Consider the following three-step transformation of the gas:
1. The gas is heated at constant volume until the pressure reaches A p_1 (where A >1).
2. The gas is then expanded at constant temperature until the pressure returns to p_1.
3. The gas is then cooled at constant pressure until the volume has returned to V_1.
It may be helpful to sketch this process on the pV plane.
How much work W_2 is done by the gas during step 2?
Express the work done in terms of p_1, V_1, and A.
I know I have to find the integral, but I can't work out how to find pressure as a function of volume.
Please help.
Thank you
Solve the ideal gas law :)
Thanks. Found the answer.
Happy Birthday.
Thanks guys :smile:
  • · Replies 33 ·
