What is the Mystery Behind i^i? Unveiling the Intricacies of Euler's Formula
  • Context: Graduate
  • Thread starter Thread starter Max cohen
The discussion revolves around the expression \(i^i\) and its implications within the context of Euler's formula and complex exponentiation. Participants explore the nature of \(i^i\), its values, and the multivalued nature of logarithms in complex analysis.
  • One participant presents the identity \(i^i = e^{-\frac{\pi}{2}}\) and calculates its approximate value.
  • Another participant asserts that \(i^i\) is a real number and questions the characterization of mathematical concepts as "weird."
  • Some participants propose that there are infinite values for \(i^i\), expressed as \(i^i = e^{-\frac{1}{2}(2k + 1)\pi}\) for integer \(k\), with the principal value corresponding to \(k=0\).
  • Disagreement arises regarding the correctness of the general form for \(i^i\), with participants suggesting different formulations and challenging each other's interpretations.
  • One participant emphasizes the multivalued nature of the logarithm function, explaining that different choices of \(k\) yield distinct values for \(i^i\).
  • Another participant expresses confusion and acknowledges a shift in understanding regarding the nature of \(i^i\) and its values.
Participants do not reach a consensus on the correct general form for \(i^i\) and its implications. Multiple competing views remain regarding the nature of the values of \(i^i\) and the interpretation of logarithmic functions in this context.
Participants express uncertainty about the assumptions underlying their claims, particularly regarding the multivalued nature of complex exponentiation and the implications of different branches of the logarithm.
Max cohen
Take euler's formula for the identity of complex numbers:
[itex]e^{xi}=cos(x)+sin(x)i[/itex]
If we substitute the value [itex]\pi[/itex] for x it turns out that
[itex]e^{i\pi}=-1[/itex]
most of us already knew this wonderfull trick.
BUT if we substitute [itex]\frac{\pi}{2}[/itex] for x we get (because cos pi/2 = 0 and sin pi/2 = 1):
[itex]e^{\frac{\pi}{2}i}=i[/itex]
Now if you raise both sides of this identity to the power i, you obtain (since i^2 = -1):
[itex]e^{-\frac{\pi}{2}}=i^i[/itex]
Calculating the value of [itex]e^{-\frac{\pi}{2}}[/itex] it turns out that
[itex]i^i=0,2078795763...[/itex]
Isn't that just the weirdest thing ever?? :confused:
It is a real number.And i wouldn't call anything in mathematics weird.
Daniel.
That's just the principal value. There are an infinite number of values for the expression i^i, all real.
The general form is given by :
[tex]i^i = e^{-\frac{1}{2}(2k + 1)\pi}[/tex], where k ranges over all integers. The principal value is for zero k.
are you sure of that formula? try k=1.
:-p
I think you mean:
[tex]i^i = e^{-\frac{1}{2}(k + 1)\pi}[/tex]
since it works for every k*(pi/2) with zero k beeing the principal value if I'm correct
Nope.Compare the case k=0 and k=1,for simplicity.
Daniel.
I see... :shy:
Sorry, I was wrong. The general form should be [tex]i^i = e^{-\frac{1}{2}\pi(4k + 1)}[/tex].
dextercioby said:
Nope,it can't be that one.
Daniel.
Why not ?
k = 0, obvious.
k = 1, exp (-5pi/2) = z.
z^(-i) = exp(5*i*pi/2) = exp(i*pi/2 + 2*i*pi) = i
and so forth.
Alright
You said (see above)
[tex]i^{i}=e^{-\frac{1}{2}\pi(4k+1)}[/tex]
I say
[tex]k=0[/tex] (1)
[tex]\mathbb{R}\ni i^{i}=e^{-\frac{\pi}{2}}[/tex] (2)
[tex]k=1[/tex] (3)
[tex]\mathbb{R}\ni i^{i}=e^{-\frac{5\pi}{2}}\neq e^{-\frac{\pi}{2}}\substack{(2)\\\displaystyle{=}} i^{i}\in\mathbb{R}[/tex] (4)
Do you see something fishy...? :rolleyes: You're working with very real numbers...No more multivalued functions...
Daniel.
Okay,now here's what u and Max Cohen wanted to write.
[tex]i^{i}=e^{-\frac{\pi}{2}+2ki\pi} \ ,\ k\in\mathbb{Z}[/tex]
Daniel.
No, that's not what I wanted to write. I meant that i^i has an infinite number of real, distinct values as given by the general form. The form you wrote trivially gives only a single real value.
My first form was wrong because it generated values for (-i)^i as well. But this form is definitely right.
Complex exponentiation is multivalued, and yes, it can even give an infinite number of distinct real results.
Nope.Everything is in terms of real numbers.U use equality sign,and the reals have a funny way of behaving way when in the presence of the equality sign...
[tex]i^{i}=:a\in\mathbb{R}[/tex]
You're telling me that [tex]a=e^{-\frac{\pi}{2}}=e^{-\frac{5\pi}{2}}=e^{-\frac{9\pi}{2}}=...[/tex]
and that's profoundly incorrect.
Daniel.
This isn't what he's saying. He's saying that you have many different choices for [tex]i^i:=e^{i\log{i}}[/tex]. log is a multivalued function, [tex]\log{i}=\pi i/2+2\pi i k[/tex] for any integer k. The choice of k chooses the branch of log you are working with. So [tex]i^i=e^{i(\pi i/2+2\pi i k)}=e^{-\pi /2-2\pi k}[/tex] and the different values of k give different values of i^i, depending on which branch of log you're using. [tex]e^{-\frac{\pi}{2}},e^{-\frac{5\pi}{2}},e^{-\frac{9\pi}{2}},\ldots[/tex] are all valid answers for i^i, just as [tex]\pi i/2,5\pi i/2,9\pi i/2,\ldots[/tex] are all valid answers for log(i).
^Exactly. :smile:
Alright.Point taken.:smile: I never thought of it this way before,so i have a reason to thank you.
Daniel.
Daniel.
Cool. :smile: Perhaps the orig. poster was not right when he said math is weird, but math certainly is beautiful and mysterious. ;)
"The arcane pleasures of abstruse maths is only for the select few of lofty intellect and weird speech patterns"
Was that what you meant?..:wink:
Oooh, I have goosebumps. LOL. :biggrin:
  • · Replies 16 ·
