Finding Jso for Antenna Array in Vacuum
The discussion focuses on calculating the surface current density Jso required for an antenna array consisting of two infinite plane parallel sheets in a vacuum. The sheets are spaced half a wavelength apart, with current densities defined as J_{s1} = J_{so}cos(ωt) at z = 0 and J_{s2} = J_{so}sin(ωt) at z = λ/2. By applying the time-averaged Poynting vector equation, it is determined that Jso must equal 5.31 A/m to achieve a Poynting vector of 500 W/m² at a distance greater than half a wavelength from the second antenna.
  • Understanding of electromagnetic theory, specifically Poynting's theorem.
  • Familiarity with the concept of surface current density in antenna theory.
  • Knowledge of electric and magnetic field relationships in vacuum.
  • Basic proficiency in mathematical manipulation of trigonometric functions.
  • Study the derivation of the Poynting vector in electromagnetic theory.
  • Learn about the superposition principle in the context of electric fields.
  • Explore the implications of impedance in wave propagation through different media.
  • Investigate the design and analysis of antenna arrays for practical applications.
Electrical engineers, physicists, and students specializing in electromagnetism or antenna design will benefit from this discussion, particularly those focused on optimizing antenna performance in vacuum environments.
robert25pl
Antenna array consists of two infinite plane parallel sheets in the xy plane spaced half a wavelength apart and having current densities. Wave is propagating in vacuum.
[tex]J_{s1} = J_{so}cos(\omega t) \vec{i}[/tex] z = 0
[tex]J_{s2} = J_{so}sin(\omega t) \vec{i}[/tex] [tex]z = \frac{\lambda}{2}[/tex]
The time average of the Poynting vector is required to e 500 W/m^2 to the right of second antenna ([tex]z > \frac{\lambda}{2}[/tex] )
I have to find surface current Jso is needed?
I think that I have to find total E = E1 + E2 and then H. Poynting vector is given but I don't know how to surface current Jso from that. Any suggestions. Thanks
Any help please
To find the required surface current Jso for the antenna array in vacuum, we can use the time-averaged Poynting vector equation:
<S> = 0.5Re(E x H*)
First, we can calculate the electric field E by adding the individual electric fields from the two infinite plane parallel sheets:
E = E1 + E2
Since the electric fields are perpendicular to the sheets, we can use the superposition principle to add them. E1 is in the positive x direction and E2 is in the negative x direction, so the total electric field E is simply:
E = (E1 - E2)
Substituting the given expressions for E1 and E2:
E = Jso(cos(\omega t) - sin(\omega t))
Next, we can calculate the magnetic field H by using the relationship H = (1/\eta) x E, where \eta is the impedance of vacuum (377 ohms).
H = \frac{1}{377}(E1 - E2)
Substituting the expression for E:
H = \frac{1}{377}Jso(cos(\omega t) - sin(\omega t))
Finally, we can substitute the expressions for E and H into the Poynting vector equation and equate it to the given value of 500 W/m^2:
<S> = 0.5Re(E x H*) = 500 W/m^2
0.5Re(Jso(cos(\omega t) - sin(\omega t)) x \frac{1}{377}Jso(cos(\omega t) - sin(\omega t))) = 500 W/m^2
Simplifying and solving for Jso:
Jso = \sqrt{\frac{1000}{377}} = 5.31 A/m
Therefore, a surface current of Jso = 5.31 A/m is needed for the antenna array in vacuum to have a time-averaged Poynting vector of 500 W/m^2 at a distance greater than half a wavelength from the second antenna.
  • · Replies 17 ·
