How can I use Monte Carlo integration for non-rectangular regions?
  • Thread starter Thread starter steven187
    Monte carlo
This discussion focuses on implementing Monte Carlo integration for non-rectangular regions using Mathematica. The user initially created a code for rectangular regions and sought assistance in adapting it for a specific non-rectangular domain defined by the inequalities {y <= x <= 4y, 0 <= y <= 2}. The solution involves maintaining two running totals: the sum of function values within the rectangular region and the count of points that fall within the specified non-rectangular area. The final integral value calculated using the provided method approximates 40.062, which is close to the exact integral of 40.
  • Mathematica programming skills
  • Understanding of Monte Carlo integration techniques
  • Familiarity with double integrals and non-rectangular regions
  • Basic knowledge of random number generation in programming
  • Explore advanced Monte Carlo integration techniques in Mathematica
  • Learn about optimizing code performance in Mathematica
  • Study the implications of using different functions in Monte Carlo integration
  • Investigate alternative numerical integration methods for non-rectangular domains
Mathematicians, data scientists, and programmers interested in numerical methods, particularly those working with Monte Carlo simulations and Mathematica for complex integrals.
steven187
Dear friends
I have been trying to write a code in Mathematica for solving a double integral with a non rectangular region through monte carlo integration, I have written a code that will solve for rectangular regions but i have no idea how to change it to work for non rectangular regions
for example let the function be fun[x_,y_] := 2x
what do i need to do to make this code to solve it for the non rectangular region {(x,y):y<=x<=4y,0<=y<=2}
fun[x_,y_] := 2x
a =
b =
c =
d =
Monte2D[n_]:=(b-a)*(d-c)/n*Sum[fun[Random[Real,{a,b}],Random[Real,{c,d}]],{n}]
nsamples=1000; nrepetitions=100;
mc=Table[Monte2D[nsamples],{nrepetitions}];
Print["For n=",nsamples," with ",nrepetitions," repetitions, \
mean=",Mean[mc]," st.dev.=",StandardDeviation[mc]
Please help
You calculate the integral in the rectangular region, as you have done, but for the smaller domain, you need to check to see whether each (x,y) point is inside the smaller domain.
The way I would do it would be to keep two running totals: the sum in the rectangular region(=sum), and the number of (x,y) points generated that are inside the smaller domain(=npass).
The answer will then be: sum*npass/nsamples
I'm not sure if this can be done without revamping your code. But I'm not a expert on the intracacies of Mathematica.
Thanks guys. It was very interesting and I learned a lot. This is what I came up with. I checked it against the integral of the indicated function over the specified domain. The integral is 40. The routine below returns 40.062.
Code:
fun[x_,y_]:=2 x;
MonteTest[fun_,nsamples_,nreps_,a_,b_,c_,d_]:=Module[{sum,tlist,xval,yval},
      tlist=Table[0,{nreps}];
      For[j=1,j<=nreps,j++,
        npass=0;
        sum=0;
        For[i=1,i<=nsamples,i++,
          xval=Random[Real,{a,b}];
          yval=Random[Real,{c,d}];
          If[yval<=xval && yval>=xval/4,
            sum+=fun[xval,yval];
          tlist[[j]]=sum*(b-a)*(d-c)/nsamples;
      Return[Mean[tlist]];
MonteTest[fun,1000,100,0,8,0,2]
Edit: Oh God. Should I not be doing this for Steve? You know Steve, I'm not sure this it right. Needs to be checked with other functions, other areas, perhaps optimized. It ran kind of slow. Don't use this for homework Ok?
Edit2: Ok, the tlist needs to go outside of the first For loop. Nevermind Steve.
