Analysis / compactness proof check
  • Context: Graduate
  • Thread starter Thread starter eckiller
    Analysis Proof
The discussion revolves around a proof concerning the compactness of the union of a finite number of compact sets in R^n. Participants explore the validity of the proof and clarify the conditions under which the theorem applies, focusing on the distinction between finite and infinite unions of compact sets.
  • One participant presents a proof that the union of two compact sets is compact and suggests applying this to a finite number of sets.
  • Another participant questions the validity of the proof, citing that while the union of two closed sets is closed, the union of infinitely many closed sets is not necessarily closed, providing a counterexample with compact sets in R.
  • A later reply emphasizes that the original proof concerns a finite union, clarifying that the theorem applies only in this context.
  • Another participant suggests that the proof could be simplified by focusing on the existence of finite subcovers for the compact sets, rather than relying on the closed and bounded characterization.
  • One participant acknowledges a misunderstanding regarding the nature of the union, admitting to misreading the problem's conditions.
Participants express disagreement regarding the validity of the initial proof, with some arguing that it is not valid for infinite unions while others clarify that the discussion is specifically about finite unions. The discussion remains unresolved regarding the best approach to articulate the proof rigorously.
There is a noted distinction between finite and infinite unions of compact sets, with the theorem's applicability being limited to finite cases. Some participants highlight the need for careful notation and rigorous writing in proofs.
eckiller
Hi,
I think this proof is easy, but would like someone to check my work since sometimes I miss technicalities on these "easy" proofs.
Let K1, ..., Kp be compact sets in R^n. Show that union( Kj, j = 1 to p) is a compact set in R^n.
Proof.
We show that if K1 and K2 are compact then K1 union K2 is compact. Then
apply this fact finitely many times to conclude the original statement.
I have a theorem: A set E in R^n is compact IFF E is a bounded closed set.
Then if K1 and K2 are compact, they are bounded and closed.
Then the union is closed. We define a bounded set as a set contained in the
open ball B(0, r), where 0 = (0, 0, ..., 0). K1, and K2 bounded implies K1
contained in B(0, r1), and K2 countained in B(0, r2). Then pick r = max(r1,
r2). Then K1 union K2 contained in B(0, r). And hence K1 union K2 is
bounded. Thus K1 union K2 is a compact set.
Remark: After you edited, you took out the first sentence of your proof. That is, the generalization that if the union of K1 and K2 is compact, then the union of an infinity of compact sets is also a compact.
Is your new proof based on that argument as well?
Yes, I overwrote it by accident when I copied my new version of the proof in.
Ok, well I'm no analysis guru but I believe this argument is not valid. For exemple, in R, the union of two closed sets is closed but the union of an infinity of closed is generally not closed.
And here's a disturbing example of an infinite union of compact set of R that is not closed, and hence not compact:
[tex]F_n = \left[\frac{1}{n},1\right], \ \ n \in \mathbb{N}[/tex]
F_n corresponding to each integer is closed and bounded by 1, and hence compact (according to the theorem you state). But
[tex]\bigcup_{n=1}^{\infty}\left[\frac{1}{n},1\right]=(0,1][/tex]
is not closed. (Example taken from my real analysis textbook)
Thanks for the reply. But note that mu union is finite. j = 1 to finite number p.
eckiller said:
Hi,
Proof.
no need to use that; it's not that complicated. since each one of your sets has a finite subcover, their union will also have a finite subcover. it's just a matter of writing it down in a rigourous way now & fiddling with the notation. (& yes the theorem is only true for a finite # of sets)
Aw man, I hadn't paid attention to "from j=1 to p" and i misread "finitely" to "infinitely" .. time to go to sleep I think.
