Measuring surface tension / bouncing water droplets
This discussion focuses on measuring surface tension and the phenomenon of bouncing water droplets. The experimental methods for measuring surface tension were sought, emphasizing the importance of understanding molecular polarity and surface interactions. The bouncing behavior of water droplets is attributed to surface tension and the arrangement of water molecules, where the negative ends of the molecules repel each other, creating a temporary barrier. This interaction is crucial for comprehending the dynamics of droplet behavior upon impact with a water surface.
  • Understanding of surface tension measurement techniques, such as the Wilhelmy plate method.
  • Knowledge of molecular polarity and its effects on liquid behavior.
  • Familiarity with fluid dynamics principles, particularly regarding droplet impact.
  • Basic grasp of intermolecular forces and their role in liquid interactions.
  • Research the Wilhelmy plate method for measuring surface tension.
  • Explore the principles of fluid dynamics related to droplet impact and behavior.
  • Study the effects of molecular polarity on surface interactions in liquids.
  • Investigate the role of air pockets in droplet dynamics upon impact with surfaces.
Researchers in fluid dynamics, chemists studying surface phenomena, and engineers working with liquid materials will benefit from this discussion.
echoSwe
Hello!
Question one: How do u measure the surface tension? (I'm looking for the experimental method now, not the theoretical one by itself)
Question two: When ejecting water droplets at a high velocity at a small angle to a water surface/body, the droplets might not merge with the body of water, but rather bounce off it and lay a couple of seconds as droplets before merging with the body of water.
Why?
It has got to do something with surface tension and the polarity of the molecules being directed outwards I think. The surface tension in the manner that the droplets bounce off due to the speed they hit the surface at, and polarity because they don't merge. But how exactly does this work? I'm thinking that the H-O-H turns its negative side (the O) inwards in the droplets, and the surface of the water body behaving in the same way, turning the outer molecules inwards (the O towards the body itself). The charges + and + hence appell each other and the droplet may be able to float a while.
The question is how this works _really_? I've heard something about charged tops or something, or is it that an airpocket is created between the droplet and the body? Please help me =)
Cheers
Henke
Anyone?
I really need help??!
  • · Replies 33 ·
  • · Replies 26 ·
