Frequency - Temperature characteristics of transformer winding
In summary, when a transformer is operated at 230V, 5A, and 50 hz the transformer winding saturated temperature may be some value. When the same transformer is operated at 230V, 5A and 40 hz (reduced frequency), the winding temperature will probably decrease.
makkena
Dear Sir,
The rating of a single phase transformer is 230V / 230V (1:1), 5A, 50 hz, 1200W.
When this transformer is operated at 230V, 5A, and 50 hz the transformer winding saturated temperature may be some value. Now when the same transformer is operated at 230V, 5A and 40 hz (reduced frequency), what will happen to winding temperature? will temperature decrease or increase? what can be the reasons for temperature change?
is there any relation between frequency and winding temperature of transformer?
Thank you
when the same transformer is operated at 230V, 5A and 40 hz (reduced frequency),...
The transformer will probably burn up.
Its core will overheat from too much magnetic flux
and its windings will overheat from the high current required to create that flux.
Go back to your very basics:
Since voltage is derivative of flux,
flux must be integral of voltage
∫sin(ωt) = -(1/ω) X cos(ωt) + C... and since it's AC we'll ignore the constant of integration C.
ω is in the denominator
so as ω gets smaller the result gets bigger
and that's why for a constant voltage, as frequency goes down flux goes up .
look up "volts per hertz";
see
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/transf.html
and
http://www.allaboutcircuits.com/vol_1/chpt_14/4.html
and here's a brief summary:
A transformer is designed to operate at or below a maximum
magnetic flux density in the transformer core. Above this design
limit the eddy currents in the core and nearby conductive
components cause overheating which within a very short time
may cause severe damage. The magnetic flux in the core is
proportional to the voltage applied to the winding divided by
the impedance of the winding. The flux in the core increases
with either increasing voltage or decreasing frequency. During
startup or shutdown of generator-connected transformers, or
following a load rejection, the transformer may experience an
excessive ratio of volts to hertz, that is, become overexcited.
When a transformer core is overexcited, the core is operating
in a non-linear magnetic region, and creates harmonic
components in the exciting current. A significant amount of
current at the 5th harmonic is characteristic of overexcitation.
https://www.gedigitalenergy.com/smartgrid/Mar07/article5.pdf
old jim
1. What is the purpose of studying the frequency-temperature characteristics of transformer winding?
The frequency-temperature characteristics of transformer winding is important for understanding how a transformer will perform under different operating conditions. This information is crucial for designing and selecting appropriate transformers for different applications.
2. How does the frequency affect the temperature of transformer winding?
The frequency has a direct impact on the temperature of transformer winding. As the frequency increases, the transformer winding experiences higher eddy current losses, which leads to an increase in temperature. Conversely, at lower frequencies, the winding has lower eddy current losses and thus a lower temperature.
3. What is the relationship between frequency and winding resistance?
The winding resistance of a transformer increases with frequency due to skin effect. Skin effect refers to the tendency of alternating current to concentrate near the surface of a conductor, resulting in an increase in effective resistance. Therefore, as the frequency increases, the winding resistance also increases.
4. How does the frequency-temperature characteristics of transformer winding affect the efficiency of a transformer?
The frequency-temperature characteristics of transformer winding play a crucial role in determining the efficiency of a transformer. This is because the temperature of the winding directly affects its resistance and losses, which in turn impact the overall efficiency of the transformer. A higher temperature can lead to increased losses and reduced efficiency.
5. What factors can influence the frequency-temperature characteristics of transformer winding?
The frequency-temperature characteristics of transformer winding can be influenced by various factors, including the material used for the winding, the design of the transformer, the ambient temperature, and the loading conditions. Additionally, factors such as the frequency range and the type of cooling system used can also affect the temperature characteristics of the winding.
  • Electrical Engineering
