Finding Resistance and Inductance of solenoid
The discussion revolves around calculating the resistance and inductance of a solenoid constructed from copper wire wrapped around a toilet paper roll. Participants are exploring the relationships between the physical dimensions of the solenoid, the properties of the wire, and the relevant equations for resistance and inductance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to determine the resistance first, considering the thickness of the wire layers. There is discussion about calculating the number of turns in the solenoid based on the roll's dimensions. Questions arise regarding how to find the total length of the copper wire and the correct interpretation of the equations for resistance and inductance.
Some participants have provided guidance on calculating the number of turns and the relationship between turns and the solenoid's length. There is an ongoing exploration of how to derive the necessary parameters for the inductance calculation, with some clarification on the definition of turns per unit length.
Participants are working under the constraints of specific dimensions and properties of the materials involved, such as the resistivity of copper and the physical dimensions of the solenoid. There is an emphasis on the need to account for multiple layers of wire in the calculations.
teknodude
The inductance of the solenoid determines the time it takes to establish this current. Find the inductance,the resistance, and the time constant of a solenoid that is constructed by wrapping five “tightly wound” (i.e., wire-against-wire like this ) layers of 0.30 mm diameter copper wire on a toilet paper roll that is 11.5 cm long and 4.3 cm in diameter. (The resistivity of copper is 1.7 x 10^8 ohm-meter. Hint: Find the number of “turns” in the solenoid. You may assume that the diameter of each turn is 4.3 cm.)
radius of copper wire= 1.5x10^-4 m
radius of toilet paper roll= 0.0215m
length of TP roll= 0.115m
I'm thinking that i need to find resistance first, but what's confusing me is that the toilet paper roll is being wrapped by layers of copper wire. So I might have to take into account of the added thickness of the toilet paper roll.
I know I have to use the following equation:
[tex]R=\frac{\rho L} {A} [/tex] rho is the resistivity, A=cross sectional area, L=length
The hint says to find the number of “turns” in the solenoid. I'm thinking that in order to find the # of turns is to take the given length and divide by the circumferance of the TP roll.
[tex]# of turns=\frac{0.115} {2\pi*1.5*10^-4} [/tex]
But then how do i find the length of the copper wire?
I know the answer for the resistance is 62.3 ohms. I tried working backwards and found that the L=259meters. I can't seem to get that length... what i am i doing wrong
The number of turns will be the length of the roll divided by the diameter of the wire times 5 for the 5 layers. The length of each turn is one circumference of the roll.
Thank you olderdan
Also for calculating the inductance, I am using this equation
[tex]L=\mu_0n^2V [/tex]
n is the number of turns per unit length. Do i just divide the number of turns that i got from the first part by the length of the wire to get n?
teknodude said:
Thank you olderdan
It is the number of terns per unit length of the solenoid, not per unit length of the wire.
10K
